After Market Tach
Old Jun 10, 2004 | 02:54 PM
MakeitQuick92RS's Avatar
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
After Market Tach
Hey everyone;
My tach just kicked the bucket, which means now i have a reason to get an after market one . Can you guys recommend one? Are any of you using aftermarket tachs? Mine was cool but when you hit the gas now it isn't accurate the guage jumps around a lot. Its fine when your at idle. I changed it for another one i had on another V6 it does it less but still does it. Aside from the after market tach qusetion what can be wrong with my stock tach?
Old Jun 10, 2004 | 07:08 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
check your connections under the hood. check the wires that go to the coil and there's a gray connector inline with one of the wires, that's the "filter," make sure everything is cleanly plugged in.
Old Jun 11, 2004 | 11:31 AM
Engine: 383 Stroker
Would my ignition coil have anything to do with the tach needle jumping around?
Old Jun 11, 2004 | 12:50 PM
Car: 91 Camaro
i'm not realy sure if a bad coil can cause that or not...its possible i suppose.
Old Jun 11, 2004 | 02:42 PM
Engine: 383 Stroker
Reason i ask is because my coil is shaky. I can't move the coil on my V8. but it shakes on my 3.1.
Old Jun 11, 2004 | 05:16 PM
Car: 91 Camaro
shaky as in loose? if that's what you mean, see if you can get a "C" clamp on it temporarily to see if that helps your problem.
$750 L98
Feb 1, 2025 02:25 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Eric-86sc
Sep 28, 2015 11:37 AM
TrevinE
Sep 14, 2015 03:20 PM
