balancer bolt thread size?
Old Jun 13, 2004 | 02:12 PM
eddie jr's Avatar
Did a lot of searching for balancer / timing chain installation and determined that the best method if an installer is not available is to use a threaded rod. I just wanted to verify that the threads are 7/16 -20 fine (for the 2.8). The posts where I saw this were in general engine tech so I wasn't sure if it is the same for 2.8 and 305/350.
Old Jun 14, 2004 | 06:54 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I thought it was metric
Old Jun 14, 2004 | 01:36 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
It is metric. Definitely not the same bolt the small blocks use.
Old Jun 14, 2004 | 04:45 PM
eddie jr's Avatar
Any idea what size? I want to prepare a rod as mentioned by others but want to be prepared ahead of time as it is my only vehicle for getting around right now.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
toronto formula
Nov 10, 2015 06:17 AM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
Linson
Aug 21, 2015 02:12 PM
knight72
Aug 10, 2015 09:32 PM
