I think its impossible...
Old Jun 21, 2004 | 05:42 PM
MakeitQuick92RS's Avatar
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
Is it impossible to put every single horse power from your crank to the ground? If so what would have to be done?
Old Jun 21, 2004 | 06:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yes it's impossible.
Old Jun 21, 2004 | 06:10 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
depends on the engine. Jet engines are probly the closest.
Old Jun 21, 2004 | 07:47 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
ummm....yup what they said...
Old Jun 21, 2004 | 08:09 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Re: I think its impossible...
Ride horseback
Old Jun 21, 2004 | 09:02 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
no way to get EVERY hp
to do that though (in a theoretical world) you would have to remove all friction from the bearings in the transmission,rear end, axles, wheels, and such
you would all have to reduce any and all losses from air resistance
the parts wouldh ave to have NO mass/weight to reduce inertial loss
so yeah
not going to happen
Old Jun 21, 2004 | 09:48 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Just bolt a tire to each end of the crank shaft and learn to balance real well.
Old Jun 21, 2004 | 10:08 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
jet engines don't put power to the ground.
anything that has a tranny or any kind of weight to turn or anything like that, you'll lose some hp.
Old Jun 22, 2004 | 12:35 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
We get into the sillyest debates on this V6 site.
Old Jun 22, 2004 | 01:45 PM
Car: 91 Camaro
lol...i'm sorry. i just had to throw that last post in there.
Old Jun 22, 2004 | 02:05 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: Re: I think its impossible...
Ride horseback
Old Jun 22, 2004 | 02:53 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Ride horseback
you would still have losses though
the horse would still have friction from wind with the legs pumping
the innefficient motion of the horses legs are going to cause some losses
pumping loss from the horses breathing
friction from the horses hooves on the ground
the hairs on the horses legs rubbing against one another forcing some friction
so even that isn't perfect
Old Jun 22, 2004 | 03:52 PM
Car: 91 Camaro
Re: Re: Re: I think its impossible...
but, you've still got one horsepower.
Old Jun 22, 2004 | 04:19 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Re: Re: Re: Re: I think its impossible...
maybe so but you still have loss and not all of it goes to the ground
Old Jun 22, 2004 | 10:36 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
so by your logic, you would also have an engine that has an infinite amount of HP. The engine puts out HP at the crank and that is what we are talking about, not getting the actual specific energy of the fuel being used. Looking at it this way, no matter how lumpy the horse is, with it's inherent losses, you are still making 1 HP.
Also, wind resistance doesn't actually change the amount of power that you make, it just changes the amount of power that is used to actually propel the vehicle. If you are putting 300HP to the ground with 0 wind, you are still putting 300 HP down with a 30MPH headwind, you just have to expend more of it to overcome the wind, so you waste some, but it's still put to the ground.
But in answer to the original question...no, it can't be done. You just have to cut your losses and make more power!!!! <insert evil laugh here>
Old Jun 22, 2004 | 11:25 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
ah yes 1 horse might still be putting out 1 hp in the easy way
BUT not the real horsepower used in physics
as far as wind resistance it can actually cause a less of power
think about it wind resistance isn't just put on on the front o the object causing it not to move forward as fast
but you also have resistance on the legs or wheels preventing them from turning which would prevent power from being applied to the ground
also on the horse with the hairs on the legs with the wing would cause them to vibrate which could possibly unbalance the motion of the horse causing minute loss in power which even small as it might be still is loss of power
and if you follow the REAL def of horsepower not
it is a horse and there is only one so that is one hp
you aren ot putting all the power to the ground
Old Jun 23, 2004 | 12:14 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
House power is equated to a medium size horse- just ride a very large horse like a Clydesdale and the subject just became null and void. Fact is, on a large horse under any condition (other than contracting phneomonia) will always put out a definitive 1 HP.
Overclock (Billy), Just for kicks (Horse kicks that is) can we see just how bizarre this can get without locking it. This V6 board never ceases to amaze me.
Old Jun 23, 2004 | 02:23 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
true
this is an interesting discussion and getting bizzare as to what we are arguing over
and so far all in good fun no flames or anything yet (stupid vsixtoy boy yeah yeah you heard me STUPID sorry I had to it's not TGO without the flames )
the REAL def of horsepower is 33,000lbs/ft per minute
so if a horse was only doing 20,000lbs/ft per minute yes I guess under your def it is still 1 horsepower BUT the real def according most any physics person will tell you that the 33,000lbs/ft per minute is the correct deff
so that horse putting out 20,000lbs/ft per min isn't really putting out a full horsepower even though the horse is the thing doing the powering
Old Jun 23, 2004 | 05:20 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
As long as this doesn't turn into flame city, I don't care how bizarre the conversation gets... it's got a tech aspect... kinda...
Old Jun 23, 2004 | 05:30 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
2_point8_boy your quote is in accurate but good response.
Old Jun 23, 2004 | 09:14 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
what a damn goofy discussion. We all need to get laid, we are wasting WAY too much energy on this.
Old Jun 23, 2004 | 10:59 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
hey I get laid all the time
but keep this on topic
consider this your first warning 2.8
but vsixtoy you have a reply yet?
