Power Steering Pump Replacement
Old Jun 27, 2004 | 11:50 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Has anyone replaced their power steering pump on a v6?? Can you get the bolts out w/o pulling the front pully?
I have a 3.4 pump and bracket as extra. I read somewhere the bracket changes its location. However, is the pump itself the same?
Need help fast as I plan to take the car on its first road trip this coming weekend and dont have much time during the week.
Old Jun 27, 2004 | 12:33 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Gotta pull the pulley, no choice. Rent it from Oreily's, Autozone or another. The braxket for the 3.4 is different I believe (I'm almost positive it is).
Old Jun 27, 2004 | 12:34 PM
FbodTrek's Avatar
Oh yeah: The pumps are the same . I actually used my spare that came with the 3.4 on a buddies TA w/ V8.
Old Jun 27, 2004 | 02:52 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Jay, just like the other post stated, you should also replace the tensioner.
A bad tensioner is almost always the result of one of the other accesories going bad (Waterpump, alt, A/C,etc). When the tensioner is not functioning properly, it will create increased strain on the bearings of everything else.
This is not always the case, but mostly- old age is the other factor.
Old Jun 28, 2004 | 10:22 PM
KED85's Avatar
Use original vehicle PS brackets onto the later pump from 3.4 engine.
Use original vehicle PS pulley onto the 3.4 pump.
Thsoe damn hoses are pain in butt for tightening, tho.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
justin57
Aug 20, 2015 07:05 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
