major smoke from Coil
Old Jul 11, 2004 | 11:24 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Car died, pulled off, could not restart, pul ECM fuse to reset just incase, cus car would not start, plug back in, hear fuel pump, and then smoke comes rolling from the coil. Get a ride home, get my after market GM blaster, plug it in and try to start, no spark
And i jsut replaced the rotor cus studs striped and front right wheel would not stay on, well lugs woundnt, wow my day has sucked
Old Jul 11, 2004 | 11:27 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
sounds like your having a really bad day man ..sorry to hear that ......did you ever get the spark figured out ?
Old Jul 11, 2004 | 11:40 PM
Car: 87 Firebird
Engine: 5.3 76mm
just happend 2hrs ago =[ dont know aobut spark, pretty sure i dont have spark, didnt really feel like getting shocked my self, having the car towed tomarrow morning
Old Jul 12, 2004 | 02:33 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
coil smokage prolly damaged the ICM (or the ICM fried the coil) ... hopefully nothing seriously wrong went down and the ECU is still okay. Major diagnostics time.
Old Jul 12, 2004 | 06:45 AM
THEGENERAL's Avatar
yeah doesnt sound to good
Old Jul 12, 2004 | 08:55 AM
Car: 87 Firebird
Engine: 5.3 76mm
ECU damage
well just got the tow truck called, 45 + 2.50 per mile gota go 3-7miles, going to a trusted mechanic, he said sure i can fix that cant wait to hear how much, wonder how close im getting to just drop in a new motor, or getting a new car, any one know any really good condition LT1 F-bodies for sale around KC
Old Jul 12, 2004 | 10:41 AM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
overdraw in coil will also hit the ignition modulator. That goes and no spark as well. The modulator was put in place from the old HEI systems to help protect the ECM from feed back.
If you can get ahold of a 90-92 3.1 harness, I have a map sensor and good ECM that I could get ya.
Old Jul 12, 2004 | 11:29 AM
Car: 87 Firebird
Engine: 5.3 76mm
Car should be in the shop getting diagnosed now, im giong to see how much they quote me at, cus i kind of need the car for work tomarrow, so its got to get fixed asap.
Old Jul 12, 2004 | 12:48 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Just nit-picking, but it's an ignition module, not a "modulator"...
Old Jul 12, 2004 | 01:32 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
According to M-O-D it is a modulator. but since were all americans we go with module.
Question. Why would one pull the ecm fuse when the car died?
Old Jul 12, 2004 | 02:29 PM
Car: 87 Firebird
Engine: 5.3 76mm
Well its the ignition Modulator, 265 total, and hopefully car will be done in another 1-2 hrs
things like this just make me want to drop in my 350 with a built 700R4 more and more
Too bad its sitting in my truck/Street rod Project
Old Jul 12, 2004 | 03:17 PM
TechSmurf's Avatar
Engine: LS1, Scrap
Last time my ignition module fried I spent 30 bucks and swapped it in a parking lot in about 10 minutes with no prior experience replacing an ignition module.... seriously man, time to start doing your own work
Old Jul 12, 2004 | 05:16 PM
V6sucker's Avatar
Engine: blown up
But the 350 has the same ignition system. So the problem would have been the same.
Old Jul 12, 2004 | 06:19 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Sorry to hear about your car man, but were you the one in the other thread talking about holding the throttle wot for like 2 seconds to listen to the motor scream?
Old Jul 12, 2004 | 07:03 PM
Car: 87 Firebird
Engine: 5.3 76mm
lol must be ignition related and not valve float related
i still have 205XXX miles on my car, and its about time some stuff starts to fail, motor goes, new car, or new bigger motor
The 350 is an older HEI system, little easier to work on, or atleast to me
Old Jul 13, 2004 | 12:26 AM
br()bert's Avatar
Car: 85 firebird
the 350 is WAY easier to work on.
RedLeader289
May 28, 2019 01:47 PM
FormulasOnly
Jul 23, 2018 08:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
