harmonic balancer clearance?
Old Jul 15, 2004 | 10:44 PM
eddie jr's Avatar
ok, just installed a new harmonic balancer cuz the old one was pooched (rubber was sliding right out and outer ring shifting), and it seems to be super close to the oil pan. I mean REALLY close....like 2mm, 3 at the most! I never though of crawling under to check that before but I can only assume it would have to have been the same cuz the balancers look identical. The front "lip" of the oil pan literally stickes in the hollow in the back of the balancer and almost touches the hub and rubber ring. Just kinda worried about that though, is that normal? Seems aweful close.
This is an 85 if that makes a difference.
Old Jul 15, 2004 | 11:32 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
put it in till it hits the crank stop.
Old Jul 16, 2004 | 06:25 AM
eddie jr's Avatar
I did, but this is how close it is to the oil pan....just wondering if that is normal cuz it just seems weird.
Old Jul 16, 2004 | 09:15 AM
V6sucker's Avatar
Engine: blown up
No, all balancers are that close. The closer they are to the source of the problem (the internalcrank arms) the better they do their job.
If you start the car and hear scraping worry. If not it's all good. Iknow they can be noticably close. It's OK.
Old Jul 16, 2004 | 02:49 PM
eddie jr's Avatar
ok, cool....thanks. No scraping by the way
91 SrS
Oct 7, 2015 04:32 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
