A Couple Minor Problems Please help!!
Old Jul 25, 2004 | 02:23 PM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
Transmission: 700-r4
I have a 92 camaro rs with flowmaster exhaust. Whenever i put my car in reverse my exhaust rattles like crazy and that is the only time that this happens. Also another problem that comes and goes is when i push on the accelerator there is a clunking noise under my feet and i can feel the vibration or something hitting like the underside below my feet....Any suggestions on what this might be??
Old Jul 25, 2004 | 03:40 PM
Xceleratemaro's Avatar
check your trans mount..might be the problem..dose it happen when you put the car in gear do you hear a clunk? or when you take off?
on a side note you might want to get under your car and shake your muffler and see if the mount are broke
Old Jul 25, 2004 | 11:42 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
i'd be 99% sure that ur second problem is a transmission mount...your first problem is probably a broken exhaust hanger, as these cars are old...the old hangers will slowly deteriarate until they brake, give your exhaust some shakes and see what moves...also look under the car for the broken hanger.
Old Jul 26, 2004 | 12:39 AM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
It clunks when i start to go sometimes and it also clunks when i put it into gear....im assuming thats because its slipping like a b****. For the exhaust part ive already looked under the car and saw no broken hangers....yet when i shake the car my exhaust also rattles....confused here...maybe i over looked one.
Old Jul 26, 2004 | 12:49 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Tranny mount for the clunk, positive. As for the exhaust rattle....who knows...
Old Jul 26, 2004 | 07:52 AM
85f-bird's Avatar
Engine: 2.8L, LS1
do you have hangers on ur tailpipes? there was a time when i was missing them, and the stupid exhaust would make all types of noise. Also, is your heat shielding detaching from your catalytic convertor? Mine was coming off and made a horrible rattling noise (annoyed everyone including me) ... so i kinda pulled it off.....it's a possibility.
A broken transmission mount will give a clunk coming off the line if there's too much acceleration, might also make a noise when putting it into gear, however, i'd most likely relate your noise when shifting into gear to the old U-joints, as they get noisy w/ age.
Old Jul 27, 2004 | 12:58 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Instead of buying a stock rubber replacement trans mount for $10, spend $20 and get a polyurethane trans mount that will last forever! It's made by Energy Suspension, part # is ENS-3-1108G (black) or ENS-3-1108R (red) ... the color doesn't really matter since nobody will see it, though. Summit Racing carries it, see http://store.summitracing.com/partde...rt=ENS-3-1108G for more info.
I went thru 3 stock mounts in 3 years, then I put the Energy Suspension one on in 1997- and it's been on there ever since, no problems.
Infested
May 22, 2018 11:56 PM
neekolzun
Aug 24, 2015 04:59 PM
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 9, 2015 01:15 PM
