engine prob. i think.....o ****
Old Aug 11, 2004 | 09:01 PM
SCcamaro88's Avatar
Car: 88 camaro t-tops
Engine: 2.8-3.4 swap
Transmission: auto 700r4
ok, i just had heads machined and put on. it was running really hot before so i put a new water pump on it,new thermostate on, and so now it runs cooler. anyways...right after i redid everything i foud a small leak then make a long story short the car is makeing a loud *** knocking sound, i pulled up to a mech, and he said my engine is ****** and that it was coming from the crankshaft. so i would rather ask and of you for some advice. thanks
Old Aug 11, 2004 | 09:34 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
tear down and rebuild, or replace with a 3.4.
Old Aug 11, 2004 | 09:38 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
what kinda leak did u find? oil, coolant, just curious....
probably have a rod knocking, if you spend tons of cash on having ur heads redone, stop driving the car, remove the cylinder heads, remove that new waterpump of yours along with that thermostat, get urself a used 3.4L from the yards, use the short block along with ur newly machined heads, waterpump, intake, etc, and get the car running again. You'll most likely be happy that you did it in the long run, as the setup will give you more power, and most likely many more miles of enjoyable fun.....
Old Aug 12, 2004 | 05:07 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
if your enige starts its not screwed to bad, just isolate the problem and fix it man....but yea what kinda fluid is leaking?
Old Aug 13, 2004 | 05:24 PM
SCcamaro88's Avatar
well, its leaking oil lol but i smell antifreeze
Old Aug 14, 2004 | 02:57 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
sounds like a rod knocking? Just replace the motor man..less headache. It will actually be cheaper as well.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
