Removal of cold start injector
Old Aug 13, 2004 | 09:38 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
How do you remove the csi from the back of the block? I can barely see it under the distributor. I know there's a clip on the tube that goes to the CSI from the fuel rail. There's also a clip that holds the wire to the injector. What holds the injector in place? I think it's a small bolt unless i'm mistaken.
Old Aug 13, 2004 | 10:41 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
There is a small bolt holding the actual injector in place. However, if you don't have a plug for its hole you WILL end up with a vacuum leak. Also, don't forget to plug the hole in the fuel rail.. that can tend to be a hazard .
Old Aug 13, 2004 | 11:17 PM
sixbanger's Avatar
do u know the size of the small bolt?
Old Aug 14, 2004 | 05:01 PM
Engine: 2.7L V6
Axle/Gears: 4.41
10mm IIRC.. been a while since I've even seen mine much less removed it for cleaning.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
