3.4 stalling question
Old Aug 12, 2004 | 08:07 PM
BlazerMaro's Avatar
Hello all...I've just finished doing the 3.4 swap, and the motor runs great, except I cannot get it to idle reliably @ or lower than 1k (in park). As well, when I put it into gear (automatic) it dies. Obviously I cannot properly set/check the timing if I can't get it to stay going while in gear.
Thoughts?
I am running a carb'd setup w/390CFM Holley...recently rebuilt, was running very nicely prior to the swap. Cleaned it, changed needles, dialed in float levels, etc. Checked vacuum, and its around 19.5in and rock steady @1500RPM. Fuel flow is also not a problem.
Any help is greatly appreciated!
P.S.: No ECM of any kind.
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
C409
Sep 1, 2015 03:42 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
