Pacesetter Header Update Hopefully
Time to send Mr. Fred Gerle a question, Dale!
fgerle@pacesetterexhaust.com
From our discussions, the product whould have covered "all years".
PERHAPS Summit made the error.
Couldn't be happier to send a smile anyones way, these days!
Glad I could help ya figure out a way to spend your money!
G0D I love capitalism!!!
Car: 1986 Firebird
Engine: 2.8 V6
Actually that's how it's covered with CA's smog exemption, too; just the 2.8's for Camaros. How picky is CA? If you've got a 2.8 in a Firebird, and the EO # is for a Camaro, do the smog stations know the difference?
Car: 89 f-bird and some others
Engine: 3.4
This is gonna be sweet when I get that 3.4 sooner or later, roller rockers, new distributer, etc etc, and headers with a y-pipe even.
Maybe i'll have my tranny rebuilt with a V8 rebuild kit while i'm putting the engine together.
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Cool, Show your thanks by sending Ked $5 ea
Send me a fresh
PAT'S & GINO'S CHEESESTEAK!!!!!!
FOLLOWED BY A LEE'S HOAGIE
I sent an email to Mr. Fred Gerle to find out what is the true scoop about vehicle usage & applications, (which is a detail-beyond fitment for the later vehicles)
PS
I got a Firebird & I sure hope my vehicle can "use" these headers. I ain't buying no more Camaros, already got 2, Except I seek a 1969 for Trans Am battle!!!
PS
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
by viewing the picture shown to us of the proto-types. Smog pump is the problem.
Hopefully by 10-1-04, I can give exact details.
Car: 91 Firebird
Engine: 191ci 6cyl
No Smog hole won't be a problem for this 91firebird, I want it gone anyways...now I just wish I could get'em WITHOUT the egr mount since that's broken anyways.
Great job Karl!!! :hail: :hail: :hail: :hail:
Nocturnall, Glad I could toss a smile your way!
Yeah, Dale, by Tuesday morning, alot will have to be acomplished.
PS OF COURSE I HAD TO HAVE tossed the perfect fitting (original) kitchen sink!
Later model 3.1 mills have smog pumps set ups?
Whose stupid idea was that ancient item?
Hi Everyone!
Here is my response from MR. Fred Gerle at PaceSetter Exhaust.
IF anyone can help us, please do provide pictures for our assistance.
Send your information to - fgerle@pacesetterexhaust.com
I also asked that "Firebird" be included in the wording of the "Smog Acceptance Application".
Response from Mr. Gerle - "it actually only lists the Camaro, but that can be fixed.
As it reads now, it's 1985-90 2.8L.
When did the 3.1 first make its appearance?
Refresh me: If this header fits what I said, will it fit and hook up to smog, etc., on any other years or engines?
FG"
Give a shout to help us all!
Now is the time for those 1990-91 model year vehicles to raise your hands & voices!
FG"
Engine: 350 S-TPI
3.1 was 91-92, I thought 90 was also.
My 1991 3.1l Auto did have smog pump hole. If he needs pictures of a pluged smog pump manifold, I can do that for him.
WOOPS!
Forget the 3rd Gen model year ended with 1992 model year vehicles!
Too tired from a personal project completing on Tues. Morning.
All those with MORE ACCURATE information (than myself!) chime in.
PaceSetter Exhaust can use your knowledge & help!
PS I informed Mr. Gerle that the 2005 Caddy also uses the 60*V6 engine, "same" as in our 3rd Gens. As an added bonus, the Caddy rides on a RWD platform, too!
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Originally posted by Doward
'90-'92 was 3.1
'82-'84 was 2.8 small journal
'85-'89 was large journal 2.8
'90-'92 was 3.1
Car: 1990 Camaro RS
Engine: 3.1L v6
Transmission: 700r4 auto
Originally posted by AM91Camaro_RS
3.1 was only in 91s and 92s, wasn't it? my 91 3.1 auto HAD a smog pump.
. Supreme Member
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
'85-'86 was MPFI 2.8 small journal
'87-'89 was MPFI 2.8 large journal
Car: 1990 Camaro RS
Engine: 3.1L v6
Originally posted by TechSmurf
'82-'84 was carbed 2.8 small journal
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Thanks for the clarification Tech. I could have sworn I remembered TomP (or possibly someone else) looking that up and saying that only '87-up was large journal.
Car: 91 Camaro
kevo, small and large journal refer to the size of the journals on the crank shaft. the small journal motors were notorious for spinning rod bearings. the journals are where the rods connect to the crank shaft and where the crank shaft sits in the main caps of the block.
Car: 1986 Firebird
Engine: 2.8 V6
Actually, Doward's right, 85-89 are large journal cranks - and that extends to the 90-92 3.1's.
82-84's had a large 3rd main bearing, but the 1st and 2nd and 4th were small. This made the crank weaker.
Starting in 1985, GM cast the cranks so all 4 journals were the same size as the 82-84's 3rd journal.
Starting in 1987, GM now added a center counterweight. This was meant for the distributorless "Gen II" 2.8's in front wheel drive cars. The Gen II's had a crank sensor that would read notches in this counterweight- and of course, our f-bodies didn't use it. BUT, this counterweight allowed GM to internally balance the crankshaft. 82-86 cranks were externally balanced on the flywheel. So with an 87-up 2.8/3.1/3.4 block, you can switch the crankshaft/flywheel/flexplate out piece-by-piece and it doesn't matter. With 82-86, once you change the crank/flywheel/flexplate, you need to attach the crank to the flywheel/flexplate and have that whole assembly balanced.
All 82-95 2.8/3.1/3.4 harmonic balancers are "neutral balanced".
Hopefully that clears it up!
'90-'92 have smong puumps. The problem is figuring out weather the it injected the air at the manifold or the at the cat.
My 1992 camaro 3.1L with 5 speed has the smog pump inject the air at the cat.
Others on here have it injected at the manifold. Could this possibly be because there automatics?
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
FWIW - I've got a FWD 3.1 crank, with the timing disc, in my RWD 2.8 block right now.
Seems FWD and RWD cranks are interchangeable, which makes sense. Just be sure to stay after '87 (like Tom said) to be sure everything is neutral balanced.
Bitching, my '88 2.8 has it straight to the manifolds - T5 here, as well. I changed over to 3.1 manifolds, for no reason other than the holes for the smog pump was not on the driver's manifold. No more pipe plugs for me.
Car: 1986 Firebird
Engine: 2.8 V6
That's why the motor I rebuild (one of these years, hopefully before I'm 80 years old) is gonna be an '87. It'll be one less thing for me to worry about.
[edit] Oh and I only noticed b/c I came back to check on the Firebird/CARB EO/emissions thing- and I forgot (twice) to thank Karl for checking into it!!
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
Can't we just re-route the smog to the cat? After we put on the pacesetter headers or course.
Car: Chevy Cobalt & Camaro
Engine: 2.2 DOHC/3.1
Transmission: Not so slushy slush box/Slush Box
Axle/Gears: Stock 3.23
When I pulled my 2,8 outta my 87 Camaro. The flexplate had a weight on it. And the harmonic balancer was completly different than the one on the 3.4 so wouldn't that make my old 2.8 externaly balanced.
If you had a weight on the flywheel, then yeah, you were externally balanced... odds are, the motor got a swap sometime before you got it.
Car: 1986 Firebird
Engine: 2.8 V6
Car: 1992 Camaro RS
Engine: 5.0L TBI
My 1987 Camaro w/ 2.8L and a 5-speed has a smog pump hooked to the manifold.
My 1989 Camaro w/ 2.8L and a 5-speed has a smog pump hooked to the manifold as well.
So it is not just 90-up. I am not sure what determined whether or not a particular car recieved a smog (AIR) pump.
Engine: 383 Stroker
I'll ask again...can i just run a hose to the catalytic converter, or should i just bypass it?
Engine: 350 S-TPI
My smog pump seems to have disappered off the car at some point
I have no clue if you can just run a hose the the cat or not.
Car: 91 Camaro
makeitquick...that's one of the great things about FL...no smog checks! i assume its the same way in your area anyways. so, yes you can just bypass the smog pump; you can take it all out if you want to. good luck with the storm headed somewhat your direction, hope all is okay for you.
Car: 1986 Firebird
Engine: 2.8 V6
Er, wait, what's the difficulty? Air pump goes to the manifolds and the cat, right? I'd imagine you could buy the headers, drill holes in the primaries for the air pump pipes, and then bring them (and 6 fittings) to a body shop and ask them to weld them on. The EGR was the big problem, and Pacesetter gave that to us.
Or do I have something wrong with what I thought I knew? Everyone here said "smog pump hole" and not "holes"...
If a 90-92 3.1 just has an air line from the smog pump to the cat and nothing else, might as well leave it unless you really wanted to throw the pump away. All the aftermarket hi-flow cats I've owned (okay, only two) have had the air fitting sticking out of the side- but capped off- which works for my '86 2.8 auto (no AIR pump). So if you pulled the air pump off and still had that open fitting at the cat, just cap it off... screw a bolt into it or something, or try flattening the end of the tube with pliers and then bending it backwards (crimped shut).
Engine: 350 S-TPI
on my 91, their is only one hole for the smog pump, and I can not find the proper size threads for it. Closest I found was 1/2 something in the plumbing section. Then got some high-heat cement to keep it in.
