shift kits and exhaust and chip, also pulley's
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
what is the best shift kit for my car b&m or transgo. Also how much hp and torque can i get from a dynomax super turbo catback and a dynomax high flow cataylic converter and does the dynomax exhaust sound good similar to a v-8 or sound like a crappy 4 banger **** rocket? And what is the best computer chip and thermostat i can buy for my 3.1 firebird. also whats better for my car jet pulleys or asp pulleys?
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
transgo
dynomax at idle sounds like v8, once you get going you can tell its v6, but still no **** rocket sound. Hp, no clue.
chip, burn one yourself, or find someone to burn it for you. No over the counter one does it.
t-stat, 185 from local parts store, no specific brand, just right size n temp.
pullys, your pick. They are the same. I have had both brands, all appear to be of same quility, size, etc. However, I now have a personal problem with jet, so I wont use them.
Car: 1998 Camaro Z28
Engine: 6.0L
for most of the stuff youre looking for HP/torque gains on.... youre not gonna see a whole lot. the only way to see REAL gains is to get into internals and/or power adder.
if you go with every bolt on you can find (after tomp's tune up, lol) its gonna vary, but id guess 30/40 hp at the flywheel. others may give more exact numbers, or maybe im off, but thats what ive figured/guessed from everything.
dhonda200
Aug 11, 2015 11:50 PM
