my idle is super high
Old Aug 29, 2004 | 04:28 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
ok i my tps and maf died so i put 'new' ones that i got from cars that were at the wreckers. they tested good on my car a few months ago so i kept them incase mine died..
now when i start my car the rpm shoots up to 1600 for like 1/2 hour if its idleing and when the car is warm after driving its around 1000. i looked at the page where it says you gotta turn a torx on the throttle body to adjust the idle with iac unplugged and aldl jumpered off but i cant find my torx on the side of the tb.
anyone have pics? or can tell me how to set my idle?
Old Aug 29, 2004 | 04:35 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Right there, BTW my engine (when i had the 2.8) did the same thing untill i adjusted the iac with the adl jumpped iirc.
Old Aug 29, 2004 | 06:33 PM
Car: IROC Z
Engine: 5.7
ok i found the screw, and i did everyhting in the directions... and it worked for like 15 minutes. i shut the car off and turned it back on and its idleing at 1700 now.
i mean the screw cant really go much lower.
what am i doing wrong?
A and B are the top row most left jumpers right?
my car is noisy and i want the idle to be correct.. and not 1700
Old Aug 29, 2004 | 07:05 PM
Car: IROC Z
Engine: 5.7
ok i jumpered the right pins this time and i think it worked.... but i didnt get the car into closed loop mode because i couldnt find the wire that you unhook when you set base timing....
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Sep 4, 2015 07:57 AM
86IROC112
Aug 17, 2015 02:00 PM
