underdrive pulley questions
Old Aug 29, 2004 | 06:02 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
everybody on hear says use crank pulley only why is that? can i still use alternator, water pump, and crank together? what belt will i need with just the crank or all 3 underdrive pulleys, how much is the belt, were can i get it from, and whats the part number? one more thing how much hp will i get from just a underdrive crank pulley will i get more hp with all 3 or less with a 3
Old Aug 29, 2004 | 06:45 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
What your actually doing is slowing down your accessorys.
Using crank and alt removes to much from the alt on our cars, causing major strain on a daily driver. Race or often race, run it.
Their is no w/p pully for our cars, no way to even make one.
Belt length will depend on year and your accessorys. Whoever you buy one from should guide you on this. Cost for belt is 15-40 depending on brand, store, and your location.
Old Aug 29, 2004 | 09:00 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i run the crank and alt pulleys on my car and its a daily driver. i have no problems with it, not even at night with the headlights on. no, i've never seen a water pump pulley for us either.
dale, why do you say that there's no way to make a water pump pulley?
Old Aug 31, 2004 | 06:11 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
the pulley comes with list of belt #'s that are supposed to fit your particular accessory combo........However.........You might end up like I did and have to put the stock pulley back on, drive to the parts store, reinstall the underdrive pulley, and make several trips in and out installing different belts until you get the size that fits, then pay for that one.
Old Aug 31, 2004 | 10:38 PM
Car: 91 Camaro
just use the string method to measure for a belt.
Old Sep 2, 2004 | 04:09 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
I did the string method and it still didn't work, the belt was wrong length, I forget which way. I ended up doing what coolrimsatleast did after walking the parts store a few times. Was not a good day.
Old Sep 2, 2004 | 04:56 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Coolrimsatleast:
Which pulley did you get? Since you have an 89 2.8 Auto like mine we should be able use the same belt length w/ the same pulley. Could you post the P/N for the belt you got?
Old Sep 2, 2004 | 05:40 PM
Car: 91 Camaro
if you did the string method and the belt didn't fit, you probably got a belt as long as the string. you have to take into account the belt tensioner. you need to subtract about 2 inches to keep tension on the belt.
Old Sep 2, 2004 | 08:49 PM
Dale's Avatar
Engine: 350 S-TPI
I got it wrong, wp pully should be larger,
Anyway, I have yet to see one for us. And any other ride that comes with 3 pully, they seem to have overheating problems as daily drivers.
Old Sep 3, 2004 | 08:23 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
So how do you like the increase in your gas milage. The pully will pay for it self in the first few tanks.
italiano67
Dec 11, 2016 09:21 AM
evilstuie
Apr 14, 2016 08:52 PM
Navy8125
Aug 22, 2015 07:13 PM
redmaroz
Aug 16, 2015 11:40 PM
BOOT77
Aug 10, 2015 12:20 PM
