Found a leak , but i don't know what it is
Old Sep 12, 2004 | 10:02 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
alright guys, my cars is running rough like always but i think i found part of the problem, just down the from the drivers side valve cover, theres 2 copper coloured pipes leading into the exaust manifolds(i'm pretty sure thats what it is). what are those 2 copper hoses?
Old Sep 12, 2004 | 10:21 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
might be egr or air pump.
is the copper pipe ribbed ?
Old Sep 12, 2004 | 10:22 PM
Car: IROC Z
Engine: 5.7
hmm i probably should check that on my car too mines running really rough and loud
kretos's Avatar
Car: 89 Iroc
Engine: lb9
no, it might actually be silver
Old Sep 12, 2004 | 10:46 PM
Car: IROC Z
Engine: 5.7
but its not ribbed? what exactly is it leaking? exhaust? oil? gas?
Old Sep 13, 2004 | 08:51 AM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
I think those are your egr piping tubes, they run behind the motor. They split and go into one pipe right?
Old Sep 13, 2004 | 04:54 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
yep
egr piping, i looked today (it was dark last night) and figured out it was the egr, its got a bubbling happening (like a wet tire with a leak) right where it enters the exaust manifold
could that be making my car run so damn ****ty?
Old Sep 14, 2004 | 07:44 AM
Engine: 2.8 Lt
Transmission: 5 Spd
I don't know if an exhuast leak could make your car run to bad, and you said it is small. It may change emissions things though. I know i had to replace that on mine along with the metal tube that runs behind the motor. PITA How is your car running?
Old Sep 14, 2004 | 09:22 PM
Car: IROC Z
Engine: 5.7
just get a tube of muffler cement and cover the hole in the egr tube
gta90
Sep 15, 2015 04:00 PM
TheExaminer
Aug 26, 2015 04:59 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
