aluminum driveshaft people!!look
Car: 88 camaro t-tops
Engine: 2.8-3.4 swap
Transmission: auto 700r4
ok, this is a question i need please, if anybody knows post post post!! i have a 88 camaro with a 700r4 v6 tranny, right now im in the middle of a 2.8 to a 3.4 v6 project, out of what type of vehical and year of vehical can i get one??
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
I'm pretty sure they cam in almost all GTA's, but you will probably have to change the rear U joint, as they have a different rear end yoke for the Aussie 9 bolt.
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Not too sure about that one, I don't think all GTAs got them. I think 1LE cars did though. And you could get them out of LS1s too.
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
Originally posted by DJP87Z28
Are you sure the Aluminum dr shaft will fit. Didn't V-6 cars have a two piece dr shaft???
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
the 4th gen V6 cars got the 2 pc driveshaft. easiest way to find on ein a junkyard, is to bring along a magnet & hop from f-body to f-body, autos only.
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
I have a 4th gen LS1 (aftermarket- but made to fit stock)carbon fiber driveshaft in my car.The exact length off the top of my head is aprox 43.5" from u-joint to u-joint.
Car: 89 firebird
Engine: 2.8
Transmission: auto
well, i do know for sure that its a one piece for sure....As far as i see it i havnt seen a post yet of this kind of question, i need an exact answer to what they come out of
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
They came in top end third gens, or thirdgens that went in under warranty for vibration complaints.
You can also jack them out of 93-97 LT1 Camaros/Birds
You can also jack them out of 98-02 LS1 Camaros/Birds
They all bolt right up.
The 93-02 V6 f-bodys do have a 2-piece shaft, you dont want that.
Take a magnet with when you go "shopping"
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i saw mention of "auto's only" i have a stick shift. can i pull the alluminum driveshaft out of an automatic and use it on my manual transmision?
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i think you'll have to change the front yoke to use one from an auto on your manual. i could be wrong but its not hard anyways. also, a magnet won't hurt but remember, if you see rust on it, you know its not aluminum since aluminum does not rust.
Engine: 5.7 / 7.4
I belive the auto & stick trannies had different legnth driveshafts, that's why I mentione d autos only. since you have a manual, just look in those cars.
Axle/Gears: n/a
well i did not find one. did get a set of alumminum brake drums and a neat mettal lid for the well out of an 84` TA. had to dremal the crap out of it to make it fit, but it is cool.
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
XO, what stuff were u needing? u said metal lid, like a glovebox door? I've got one for ur style car, the rubber seperated at the bottom, but u can't tell from the top side...stopped using it when i went 4th gen....if ur interested, PM me, we can work something out.
Can get all types of aluminum parts, if you're really ballsy you can even get an aluminum engine (think ls1) then get urself that aluminum driveshaft, mix it all up with a not so aluminum t56, and you'll be in business. and having fun all the days of ur life.
Axle/Gears: n/a
no, i meant that i wanted the rear cargo cover that was mounted to the car, it folded open like the hatch does. and io allready got one now
Engine: 350 S-TPI
while in my t5 swap process, I brought out the home scale.
Our v6 driveshaft only weights 12lbs. Its smaller diameter then v8 ones.
I dont think I will be upgrading because 100-150 bucks to drop 1 lb is not worth it to me.
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Engine: 350 S-TPI
I figured you, oilpan, am91 so far are the only ones that would really need to worry about it.
I think as of right now, nobody else is close to the 200hp/250+ tq.
Car: 91 Camaro
why do you think that we will need to be the ones to worry? just considering the diameter of the stock one? you thinking its possibly a little on the small/weak side for a "higher" torque car?
Engine: 350 S-TPI
Am91, yes thats what I'm thinking. We get into the 200hp/250tq, your talking stock 305 power range, thus a v8 with larger driveshaft.
Or has anyone checked the size/weight of the 305 driveshaft? Is it a "v6" driveshaft?
Well, when I get traction, I think we'll know for sure then, if it'll handle 300+ lbs/ft of tq.
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
On juice i'm closer to 230 I'd imagine...we'll see in a few weeks when I dyno this thing... TGO Supporter
Engine: 350 S-TPI
fbod, I have no clue as to your mods, or how much power your pushing.
Doward, yes I belive you are currently the most powerful.
DDD says I'm about about 195hp, but I dont belive it. Car is to slugish compared to my old s10 that DDD rated a much less power.
I get this damn 5sp and proper gears in, I'm dynoing this basterd along with a bit of track time.
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Long tubes
Dumps
Cam (same as Doward)
3.4
50-80shot of juice, wet.
Shiftkit, built trans
Slow on motor (until the heads go on), much less slow when juicing.
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Originally posted by pasky
Autos and manuals are the same length. Any one piece drive shaft from a 85+ f-body will fit another f-body of any year except the thirdgens that got the saginaw 4 speed or the 200r4. You do not need to change the yoke on any, even going v6 to v8, or auto to manual or vice versa, all the same length.
or did the TTA's come with the 200 R4?
Engine: LS1, Scrap
you never drive yours, it dont count
... motor failed before the driveshaft, though
Car: 2000 Trans Am WS6 (Black)
so anyone that gets the turbo kit will need a new driveshaft, rebuilt tranny, rear-end, and prolly a rebuilt motor fairly soon??
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
topteam54
Oct 6, 2015 12:21 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
