Someone help
Old Sep 25, 2004 | 12:09 PM
black90rs's Avatar
Car: 82,84,90
Engine: camaros
Someone help
So let my car sit for 2 hours and i go 2 minutes down the road to the store.. sitting in the parking lot.. car was idling perpect around 7-800 rpm then out of no where it dropped down to 3-400 and would bounce until i turned it off... well i try and restart it and nothing.. just cranks and cranks... let sit for 5 minutes and it started up and idled fine.. but if i barely hit the gas it would bog out and hesitate.. like ill have the gas floored and the rpm would be at 400 rpm.. but once i get going after bout 3 minutes of holding the gas down it back fires and hesitates and bogs out.. anyone know whats up?
Old Sep 25, 2004 | 12:31 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
i'd say a clogged fuel filter might do it
Old Sep 25, 2004 | 01:33 PM
black90rs's Avatar
Car: 82,84,90
Engine: camaros
ok ill check that too... but this mainly happens after about 45 minutes of driving.. after 45 minutes the car will fall on its face at wot.. also i can put it in nuetral and floor it but it will never redline.. just sit at or under 4k rpm
