Anyone know of low temp STOCK fan switch?
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
Anyone know of a fan switch (from a different vehicle) that comes on a little earlier that the stock ones? It has to fit in the STOCK location and work. Anyone?
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
JET make 2 different ones.
The 93ish Tahoe had a lower on/off temp the ours and the GN as well IIRC from the times I've seen this asked. Granted, I've slept since then...
Do a search in the Cooling or Electornics forum for 'fan switch' and you should be able to verify that I'm only partially insane on the above...
Either forum should yeild a fairly solid answer for you though...
The fan switches were the same size throughout all SBC and 60° motors I believe. The TBI and v6 use the same (238°) switch so, I would surmize that the head threading was a pretty universal size between the v6 & 8. Just my opinion though....
(disregard my spelling as well for certain reasons..)
eightsixseven
Dec 16, 2024 01:50 PM
NBrehm
Aug 25, 2015 11:49 PM
