Codes 42/43
Old Oct 10, 2004 | 08:18 PM
coz's Avatar
coz
Codes 42/43 '92 RS 3.1
I can't shake the 42/43 codes EST/ESC. I verified/adjusted the base timing to 10* and replaced the ESC sensor, no dice. Looking at my Haynes manual it refers to the ESC module located at the firewall near the brake booster. I see no such animal. I'll replace whatever components are in the ESC system. Can someone clue me in on what needs to be replaced?
Old Oct 10, 2004 | 11:33 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
knock sensor. check it out or replace it. chances are, that's your problem.
Old Oct 11, 2004 | 10:45 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The ESC module would be mounted behind the relay bracket on the driver side firewall near the power brake booster.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
