Quick timing question, somebody please answer!
Old Oct 14, 2004 | 11:08 AM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
What is the proper timing setting for the 3.1? I dont have an underhood sticker and my Haynes doesnt list it. Right now im at about 12-15* advanced. Is that too much? My mileage sucks someone please help!!!
Old Oct 14, 2004 | 11:44 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
10 DEGREES IS STOCK. Mine runs better at the stock setting then it did when i would advance it to 12.
Old Oct 14, 2004 | 01:12 PM
Car: 88 IROC
well i guess that could explain my poor mileage. Thanks man
Old Oct 18, 2004 | 12:35 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
yeah, stock is 10*, but I run up at 18* btdc and get 23-24 mpg(M/T). I'm lovin' life right now. something to think about...if you have a misfire, then your milage WILL go down. even a small one will hurt you, if you notice a little shakyness at idle, then something is amiss. just a thought on where to look for milage.
btw...those engine mods will hurt too. especially the 3.73's. you'll probably run something like 3K rpm at 70mph.
Old Oct 18, 2004 | 01:00 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
You could just have leaky valves. Id do some compression / leak down test.
Caspar
Jun 19, 2016 11:19 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
bamaboy0323
Aug 15, 2015 07:20 AM
