What heads flow better?
Old Oct 15, 2004 | 11:42 AM
MakeitQuick92RS's Avatar
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
I was just here bored at work wondering what heads flow better the 3.4 heads or the 3.1 heads...or is it the same crap? Ebay has some aluminum 3.4 heads...the guy selling it claims they fit 3.4L Birds and Camaros.
Old Oct 16, 2004 | 01:07 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
3.1 and 3.4 heads are idential. Both are 14054884 castings.
The Aluminum heads are FWD applications. THey will fit our RWD blocks, but not our intakes. The FWD intakes are backwards facing on a RWD car so the TB would face the firewall.
Old Oct 16, 2004 | 07:44 AM
oil pan 4's Avatar
Car: 89 Firebird
Yes they will fit. They will bolt on.
If you bolt those heads on a RWD engine it will give you a round a 12:1 c/r.
Those Al heads flow about as good in there stock form as I can get cast iron heads to flow ported.
The Al heads have bigger valves then the iron ones.
Old Oct 16, 2004 | 08:32 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
12:1
and I though regular was expensive enough.
Old Oct 17, 2004 | 07:40 PM
Engine: 383 Stroker
to bad they don't work
gta90
Sep 15, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Ducati900ss
Sep 2, 2015 09:05 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
