Voltmeter reading strange behavior...
Old Oct 20, 2004 | 08:18 PM
87pontiac's Avatar
Car: 87 Firebird
Engine: 2.8l-(350 on the way)
Transmission: auto-(for the wife)
Hello everybody,
I have a good one for you.I fully charged my battery,placed it in the car,started it up,the gauge read a little over 13V. The more the engine ran the LOWER the reading would go!(leveled off at around 12V).
So I would check the battery with VOM meter and it would say 14.6V;check inside the car-less than 12.5V(no acc. on).
I put up the headlights the gauge drops the engine idle goes down slightly,first thought bad alternator or pully tensioner is done or the belt is stretched.
Anybody ever encounter this problem?
Sure would appreciate the help!!!!
Thanks !
Attached Thumbnails Voltmeter reading strange behavior...-1987-blue-eagle-inverted
Old Oct 24, 2004 | 04:14 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
alternators going, replace it soon it will crap out at the worst time
Old Oct 24, 2004 | 07:27 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Well normally an alternator will charge in the 14.5V neighborhood.. Between 14v and 14.5v... I think as your battery approaches a maximum charge, say if your batt is brand new and holding charge very well....the alternator will cut output so as to not overload the battery....and will just up output as needed for accessories. But still, if you're dipping as low as 12v.....I'd say it's a bad alt. 12 volts is absolute minimum to keep your car running. Anything less and you're draining the battery, which will kill your battery quite nicely and eventually the car will just shut off and not crank to restart.
Old Oct 24, 2004 | 11:43 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Check the voltage at the alternator and compare it to the voltage at the battery.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Fronzizzle
Sep 8, 2015 12:10 PM
SG91camaro
Sep 5, 2015 10:27 PM
IROCtometal
Sep 2, 2015 02:01 PM
