easy way to reset car?
Old Oct 22, 2004 | 12:55 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
i know that unplugging the battery will reset everything, but my battery connections are almost impossible to get off, so is there a fuse i can pull.
my car never ran properly after i unplugged the battery from the car to do my starter a while back, so i'm thinking if i reset everything and go for a half hour freeway drive to reset everything it should run better
Old Oct 22, 2004 | 02:21 PM
bry92firebird's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
Transmission: 5 Speed Manual
Try pulling the fuse for the ECM for 30 seconds and see if that helps.
Old Oct 22, 2004 | 02:57 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
1991 3.1 has fuse on passenger fender for ease of reset. Not sure if yours does or not.
Old Oct 22, 2004 | 04:54 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
the fuse coming off the battery?
Old Oct 22, 2004 | 05:36 PM
Car: 1992 Firebird
Engine: 3.1 V6
The fuse box under the dash should have a 10 amp fuse marked ECM on the box.
kretos's Avatar
Car: 89 Iroc
Engine: lb9
i'll just pull the ecm fuse
customblackbird
Aug 15, 2021 10:16 PM
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
