basic 3.4lt swap questions...
Old Oct 23, 2004 | 05:06 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
WHat vehicles did this motor come in? Are some better to use than others (were some more horsepower, better internals stock than others)? Does the 3.4 have a spot for the Cold Start Injector? What needs to be used speciffically off the 3.4 block? I think thats it for now.
Old Oct 23, 2004 | 05:07 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
3.4 outta a 93-95 camaro or firebird
finding one here in the lower rainland is a hard thing to do, and theres a tech article by ked85 telling you exactly what needs ot be done
Old Oct 25, 2004 | 02:41 PM
Slowmaro95's Avatar
From: Straight outta the red light district of Highland
Car: 2001 SS
Engine: guess...
Transmission: 4 spd w/OD
Axle/Gears: 3:73 Posi
If you were set on a V6 drop, I'd put a 3.8L in. Better overall engine that handles abuse better. I've had more issues with my 3.4L than any good boy should, lol. The three-eights also come from the 93-2002 camaro / firebird. Shouldn't cost you that much more $$.
Old Oct 25, 2004 | 03:11 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
But the 3.4 is a direct block swap! no extra work besides that...a 3.8 or v8 will require rewiring!
Old Oct 25, 2004 | 03:57 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
IF the car already comes w/an electronic speedo, the rewireing is kept to a min. Just have to splice in the vats (if yo hae it or do bypass) and the about 6wires in the engine bay. The gauge wires are jsut track down & splice. The key is to get those right (I did a gcluster swap to a newer yr & am still working those issues) and the motr mount brackets. The tranny k-member is in the same spot & 99% of all teh wiring for the 3800 to run is in the bay, alon gw/the pcm.
Old Oct 26, 2004 | 06:22 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
the 3.8 didnt show up till 95. just incase anyone goes looking for one of those
AussiePr0nCar
Mar 6, 2020 04:04 PM
InfinityShade
Feb 21, 2016 01:29 PM
ezobens
Aug 19, 2015 10:29 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Fronzizzle
Aug 19, 2015 01:36 PM
