Got a new motor..now what?
Old Oct 26, 2004 | 07:48 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
Found a motor at the wrecker today. From an 89 camaro 2.8. What things do I have to use off of my original motor onto this one? What do I do about the CSI on my car? Any thing difficult or tricky in removing motor from car?
Old Oct 26, 2004 | 07:52 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
you'll be doing the 2.8~2.8 swap boogie.
Old Oct 26, 2004 | 09:06 PM
sixbanger's Avatar
3.4s are too expensive and hard to find around here. Plus this one comes with a four month warranty
Old Oct 27, 2004 | 11:19 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
like i said they are way to hard to find around here, someone jumped on one out here that i was supposed to buy.
where did you go for yours?
Old Oct 28, 2004 | 12:02 AM
KED85's Avatar
Bummed to hear that finding a 3.4 is difficult.
You do have a RWD 2.8 available, right?
Then simply pull both engines, put side by side, strip one block of your FBody engine stuff, stick it on your other 2.8 block.
Read my 2.8-3.4 Long Block Swap boogie thread and cross out 3.4 & insert 2.8.
DETAILED yet simple.
BEFORE YA BUY that 2.8, have them offer ya the cylinder pressure readings.
My used 2.8 in my 1985 Blazer with 211,600 miles on it registered 50PSI per cylinder.
My 3.4's? They registered 175/200PSI per cylinders.
Hope that's a guide.
How about buying a beat up 1993-95 Fbody & strip the 3.4, insert your used 2.8 & dump the 4th Gen Fbody on someone else!!!
NOW WHO would do that?
In end, you are duplicating/replicating exactly what is currently under your F Body hood.
OR ya can continue to seekout a 3.4 for yourself & do same effort & gain better (more powerful) results.
The pic is of the 3.4 in Firebird. Looks just like a 2.8, right?
Old Oct 28, 2004 | 12:09 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
A shortage of 3.4 blocks up here is not good news. Hopefully there will be a few more in a year or two when I get some real work done on my car.
Old Oct 29, 2004 | 02:54 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
well, when you start looking let me know, i know the places up here to get them cheap. i'm actually next in line for one as soon as it comes in
Old Nov 4, 2004 | 07:00 PM
sixbanger's Avatar
there's 2 at Ralph's on scott road but they want 1100 each
Old Nov 4, 2004 | 07:12 PM
KED85's Avatar
Would a place in Michigan be of help to you all in Canada?
I've got a connection with a wrecking yard there.
Hey IF they are low milage 3.4 with warranties, take them!
New ones go for $2000 USD.
