When I press the brakes the lights go nuts!!!
Old Nov 3, 2004 | 07:46 AM
MakeitQuick92RS's Avatar
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
So here is the deal i have a 1992 Camaro. Yesterday i had to replace a brake light on the rear drivers side. The brake light works fine but when I press the brake pedal all the interior lights turn on except the dome light looks quite funny but i was just wondering why the hell it is doing this? Any help would be greatly appreciated. Thanks.
Old Nov 3, 2004 | 08:20 AM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Make sure that you put in the right bulb, if you put in the wronge one, it can screw up the electrical and cause this. Good Luck
Old Nov 3, 2004 | 05:00 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Make sure it is a dual filament. I had a car a while back that the brake ligts were awalys on turn signals on I could not figure out why. After i had begun to rewaire it i noticed the previous owner had put a single filament bulb in insted of a dual filament aftetr that it worked perfect.
Old Nov 3, 2004 | 07:55 PM
Engine: 383 Stroker
Thanks guys i fixed it. They gave me an 1156 the first time when they should have given me a 2057. Stupid s***** at discount auto parts...
Old Nov 3, 2004 | 08:36 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
LOL...I didnt know that would happen.
Now you guys are giving me ideas, hmmmm revenge
Vintageracer
Jan 10, 2020 05:33 PM
Dialed_In
Aug 20, 2015 01:45 PM
smooth
Aug 18, 2015 06:34 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
