Dyno Results on my 3.1
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Thanks! Glad to be back Dale!
Pillsbry10: Mine runs fine on the stock 2.8 pump. Have not noticed any real issues. But I have not put a fuel gauge on it and took it down the track either though.
Oh....I was wrong...Lt1guy had done a few bolt on mods to the 95 and changed the rearend gears, but that is all, no internal engine changes. He said he ran it down the track with the fuel gauge on it and saw it drop. Said it had always felt like the car pulled great out of the box and then dropped off like the TQ was gone. It was the lack of fuel pressure at higher RPMs.
See mine will pull hard till I'm going, then it feels like its lost its torque. Like I'm cruzin on the hwy @ 55/60 and punch it and the responce is not there like I think it should be for 207 TQ. So fuel pressure might be dropping, thats my guess. Seems that is what modding the 2.8/3.1/3.4 is...guess work! Asked around and since we have a return sys and I have the Adj fuel pressure reg, it can't hurt to go a bit bigger!
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
over at caspers electronics, they sell some device that hooks up to your tps, and alt.
When your tps is at xx% throttle, it makes the alt put out more volts. Claims to help with spark, and fuel pumps not keeping up :shrug:
As tight at my funds are, and I dont really "race" mine, I havent got it.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
V-Plus Volt Booster
V-Plus Volt Booster
https://www.casperselectronics.com/M...ry_Code=firev6
The V-Plus Volt Booster is designed to incresase your entire electrical system voltage approximately 2.2 volts above and beyond factory voltage. This unit is activated when you reach 70% throttle. This is when your whole vehicle's electrical system is under the most amount of load. The result of the increased voltage is hotter spark, incresed fuel pump flow, etc.
$80
TPS-TEC G38S
NOTE: Must have FLAT connector on TPS. TPS voltage at Wide-Open Throttle (WOT) is a function of power enrichment (PE). If the voltage is below a certain point at WOT, the ECM will reduce the level of power enrichment and the engine will not perform to its potential. This device is completely transparent until 70% TPS, then it takes over and assures maximum TPS voltage for 100% Power Enrichment (PE) when you need it the most. The TPS TEC also corrects for low sensor voltage and "dead spots". Plug-and-Play, installs in minutes. LED indicators verify correct operation.
$90
I found them both under the Firebird with the 3.8 so who knows if these will work for us.
$80
TPS-TEC G38S
$90
Originally posted by Pillsbry10
quick question....im sure most of you have read the mods im doing to my 3.4 is my stock pump gonna be ok for awhile?
and the motor's throwing over 370hp and 410 ft lbs.
I just did 12.88 @ 113.342 in the 1/4 last month. I don't
think you will have a problem! I would eventually change
it, as I am going to next spring. I would like to have peace
of mind, so I am buying a high peformance Holley pump.
Since the pump's original , over 13 years old and rated for
a stock V6, I am changing it!
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Found another one under the cavalier. They had 2.8s???
if ya search around they got lots of nifty fancy products for the 3.1/3.4
V-Plus Volt Booster
Quantity in Basket:none
Code: 102130
Price:$79.95
Round TPS / Late Alternator
Just search on the site for V-Plus Volt Booster and they have 6-7 different ones.
V-Plus Volt Booster
Code: 102130
Price:$79.95
Car: 1987 Trans Am
Originally posted by Camaro_nut
I got a 5.7L with a stock 3.1L 1991 fuel pump ( for now!)
GM pumps in general are weak from the factory. I had to
change the fuel pump in my aunt's 96 Olds Cutlass 3.1L with
40K in it. After the change, the car literally "woke up"! I couldn't
believe it! The car pulled better and cruised smoother on the
highway. FYI, most GM cars in the 90s to 2000s had
a TSB for updating the fuel pump!
Also, Fords are just as bad if not worse than GMs.
I had changed like 10 Ford pumps to every 3 GM pumps.
That's why I want to swap in the Holley pump next
spring. With the power and torque that we throw
at these cars, the stock pump can only do so much.
Even though I only need 35lph on my motor, I am
still going to change it. Years, mileage, etc. are main
reasons.
reasons.
Originally posted by LT1guy
You might be surprised; I know I was. On a relatively stock 95Z (LT1, T56, 4.11 gears) I picked up 3 tenths and 5mph in the 1/8 mile, with nothing but a fuel pump change. The car only had about 30k miles on it then (bought it new), and had never been run low on gas, so the original pump was fine. The car felt strong, and ran comparably to other like-modifed cars...until I changed the pump to a 190lph. I think the demands of a manual trans car (or a high stall convertor), launching hard (avg 5000 rpm for this car), combined with the gear ratio (was running 4.56s for a while), overwhelmed the stock pump. Redraifs car isn't making the power that one was (or that yours is), but considering her stall and gears, plus the engine mods, I'll be surprised if it doesn't pick up something. Either way, we'll post the results.
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Michigan somewhere, dont have the adress anymore lol... im was wondering if anyone from pf&e was posting still
anyways are you guys gonna be burning chips up there becuase i know im gonna need one bad after this engine goes in, and im not to far away....not to mention ill need a good tune
Maybe if we can get enough of us with modded 3.4/2.8/& 3.1s we can get a baseline program that will help everyone. give a starting point so to speak. If I was further North I would go up there. Ga is a long way from MI, esp this time of year. Been meanig to get my stock chip to funstick. I had to buy a new one, old one failed somehow. I've got a custom chip from him. It was too far off though. Maybe with my stock one he can get closer. Get us a good start.
yeah im sure we can get a few of us together that need a chip and could go up there at some point im in IN. i need to get ahold of a 3.1 manual chip as i still have my auto chip in there whicch is giving me a few problems anyways.
hopefully they can help us out....
Car: 1987 Trans Am
Originally posted by funstick
you really need to bring the car up to greg at PFE so we can tune that puppy up. im sure we can fix your flatspot no problem.
well hang tight and i might be able to setup a few dyno days. to go with the tunning. im and avid small engine guy. i love building small motors to make big power. but pillsbury if you need a chip swing north we can take care of it.
as for redraifs car needing more fuel pump ??? good question. most likely however the maf is maxed out. a stock GN maf with a properly setup chip would probably wake that puppy up. but again id need the car.
id be more than happy to come up there but it would have to be a weekend thing, i live fairly close to you guys. when i get the motor in we can arrange a time for me to come up there, what kinda cost would we be talking for a tune and chip? im looking to have the engine in over the holidays and maybe round january or febuary would be time for chip? lemme know what ya all can do for me..im probably gonna have a lot of the problems that redraif is having
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
For the Fuel pump info:
2.8 uses the same pump as the TPI 350's. Sonar and I (owner of a modded TA) changed our fuel pumps at the same time, the part numbers were the same. You won't ever have a fuel issue with going to 3.4 unless you're runing boost or lots of nitrous, even then and I doubt it.
Car: 1987 Trans Am
Car: 1987 Trans Am
If its possible to use a GN MAF, is it possible to use an LT1 MAF also (far more common, and seen often on modified GNs)? Or would a switch to speed density (say a 749) be better, esp considering the car will possibly get a turbo in the next year or so?
what ever you wanna do let me know.
Will do...I have to do something soon. My m/gal is horrible! Going to and from work is breaking my wallet. I go approx 20 miles a day to work one way. Half expressway...half surface streets...some stop and go... Car is using 1/8 of a tank per leg!
So say 40 miles per day 1/4 of tank used...15.9 gallon tank...so 4 gals used...
10 m/gal yipes! And we just tuned it up! Though at idle when in stop and go, I'm getting an intermitant code 22 & 44... TPS and O2 (lean condition) My car runs rich though! So swapped O2...checked TPS voltage OK? Go figure! Only me. So I have to do something quick that will provide some tuning.
Oh I have the a duplicate of my stock prom now if that will help! Recently I had to buy one when computer was replaced. Thought old prom was bad, but is not. So I can send it and yours & a heap of stockers from the junkyards I scavanged, if you think you can help!
you wouldnt happen to have a 90ish 3.1 manual prom would ya?
Originally posted by redraif
Thats the first I have heard that. Who parts were you buying? Dealer or parts store?
Car: 1987 Trans Am
They pumps are Carter units (Made by Federal Mogul). I think they are 205 lph (or somthing like that) My pump makes 55 psi of pressure at the rail, I have it adjusted to be 45 psi (stock regulators kick it down to I believe 42)
The problem was that until recently I did not have a spare chip to let someone read. I was stuck with the chip in the car, which meant that I had to get someone local to read it. That was the issue... Funstick needed my stock program to build from, which I could not get a local guy to read for me. BUt with the spare now I can just send it where ever or leave it with a local guy to play with...
LT1Formula
Oct 8, 2015 08:34 PM
