Dyno Results on my 3.1
Old Nov 5, 2004 | 03:03 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
ok so i decided to dyno my old engine with its mods to see what i had before i put the 3.4 in this xmas, my engine is pretty much stock 3.1 with close to 129,000 miles on it. all i have done to the engine is a k&n filter, underdrive crank and alt pulleys, bigger plug wires, pf&e headers into a deadbird exhaust, 5 speed swap and posi, thats about all for performance i know some of that doesnt affect hp and tq but figured i would list anyways.
my first question is how much hp/tq is lots in the drivetrain so i can estimate my engine hp/tq?
anyways to the numbers
first run i ran it up to what i thought was redline, come to find out it was only 5000, damn gm tach and i ended up with 132.4HP and 177.7 TQ
2nd run i ran it up to what i that was like damn near 7000, come to find out it was a little over 5500....grrr, anyways my second run i pulled 133.8HP and 178.9 TQ
not to shabby if i do say so myself, especially outtve a motor that is only rated at 140hp and 160tq...im sure if it had a good tune up id pull a lot more outtve it, i havent replaced anything on it in a long time....cant wait to see what this 3.4 im building puts out, what ya all think
Old Nov 5, 2004 | 04:11 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I think its time to pick up a $20 tach off Ebay so you know your true RPMs.
Old Nov 5, 2004 | 04:13 PM
Pillsbry10's Avatar
yeah i plan on getting one now for sure soon as the new engine is in.....well at least i know i havent been over reving it cuz i never take it up to redline, or what i thought was redline
Old Nov 5, 2004 | 04:57 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
are the stock tach really that inacurate?
Old Nov 5, 2004 | 05:01 PM
Pillsbry10's Avatar
at idle alone mine was like 400 off, at high rpms i guess it just got worse, either way im pleased with the restults...im sure if i had somene stuff replaced on the engine and reshened it up it woudl be running a lot more than what it did....oh well 3.4 here we come haha
Old Nov 5, 2004 | 06:12 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
no the stock ones are not that off. His must just be bad. I have a led tach and it maches my stock on R for R.
Old Nov 5, 2004 | 08:10 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
what kind of duno was that on? your TQ numbers are a lot higher than the dyno has showed mine! you hp numbers are about the same as mine...that doesn't make sense. you ever run your car at the track? if so, what does it run? they say about 10% loss for a manual tranny.
Old Nov 5, 2004 | 08:15 PM
Camaro_nut's Avatar
I think that the 90-92 Camaro tachs are off about 200 RPMs.
I am having the same problem as Pillsbry10. My tach is
off about 600 RPMs at idle, and gets worse off idle.
I think I am switching back to my V6 tach with the V8
chip, and see what happens. I know that one was a lot
closer than the used V8 one I bought off Ebay.
Old Nov 5, 2004 | 09:45 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
I compared mine to the ECU's readout - mine is about 300rpm behind.
Old Nov 6, 2004 | 12:43 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
I have the dummy gauges so I installed an Equus tach... I like it.
Old Nov 6, 2004 | 03:12 AM
Pillsbry10's Avatar
AM91Camaro_RS it was a dyno jey dyno...what all do you have done to your engine,im sure ive read about it before but i dont remember. yeah the tq kinda surprised me but we ran it twice and they were pretty much the same, i floored it a little quicker on the second run hence the extra power. maybe i just have a freak engine ....no i havent ran it at the track yet i was gonna this year but im having a transmission mount problem which keeps me from launching. im not sure if our track is even still open ill find out cuz i wanna go run it before i do the motor swap, ill let ya know
so estimated at 10% i would have 146hp and 195 TQ at the flywheel
as far as tachs go i probably just have a crappy one, or the tach on the dyno was way off, but hey at least i know i wasnt hurting anything when i was racing cuz i kept it below what i thought was redline
Old Nov 6, 2004 | 09:39 AM
Car: 91 Camaro
my tach is off too...
pillsbry, i think either you have a freak engine or the pf&e headers really do work better than my old hookers. cause i have headers with fully custom y-pipe to 3" single to a flowmaster, P&P heads and intake, 1.72 int 1.42 ex valves, 10.75:1 compression, BIG cam. i have been on the dyno yet with my new throttle body though. and, i need to get my new intake manifold finished so i can, hopefully, see some big improvements.
Old Nov 6, 2004 | 03:34 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
those are some impressive numbers
Old Nov 6, 2004 | 07:24 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
My tach my be off a little but not noticeable.
stock tach has 12 lines between each number.
My LCD ones has 4.
But at cruise speed 2500-3000 they match up well.
Old Nov 7, 2004 | 12:34 AM
Pillsbry10's Avatar
AMS youve still got a lot more done to your engine than i do mine i cant imagine the headers are doing that much more. what are your numbers anyways?
Old Nov 7, 2004 | 12:47 PM
Car: 91 Camaro
143hp and 165tq. that was late in the day on a dyno day so i thinkin that they calibration could have been off on the dyno. there had been some pretty powerful cars on it before me. i was rather dissapointed. but, i'm shooting for getting some high 14s N/A this winter! i've pulled a Z06 out of the hole at the dragstrip so i know it has some torque! Hemi Rams are no competition... so, i don't know.
Old Nov 7, 2004 | 01:27 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
That's it? I would think you had upwards of 200 ft/lbs. Must have been the calibration. There's a formula for determining rough HP from et's and trap speeds vs. weight somewhere....
Old Nov 7, 2004 | 06:40 PM
Car: 91 Camaro
yea, i've guessed that hp is really around 210-220 at the crank and those ET and mph formulas support that guess.
Old Nov 8, 2004 | 06:48 PM
Pillsbry10's Avatar
im gonna check to see if our strip is still open this weekend and try to get at lest one run in so i can give you some numbers.
i cant wait to get the 3.4 done....its gonna be one heck of a sleeper against all the little kids in this town and there hondas
Old Nov 8, 2004 | 07:21 PM
Car: 91 Camaro
yea, if the strip is still open, definately see if you can get some numbers! and, yes, the 3.4 will let you have even more fun against some unexpecting, um,....smaller engined cars.
Old Nov 8, 2004 | 07:29 PM
Pillsbry10's Avatar
well we are still having good weather down here low 60's upper 50's but i dunno how they stay open....its supposed to be nice this weekend so if i actually get up early enough to go down there ill get some numbers
yeah everyone in this town knows my camaro and knows that its a v6.....and i can even show them whats under the hood with the 3.4 swap and no one will know the diffrence its awesome. maybe make some money back as well
hey can you estimate times with hp and tq? id have to guess the weight on the car though
Old Nov 8, 2004 | 08:48 PM
Car: 91 Camaro
if you are making that much power, you should be running low 15s would be my guess. the weight could make a big difference though.
Old Nov 8, 2004 | 09:53 PM
Pillsbry10's Avatar
well i do have a fiberglass hood but i also have a system in it so im guessing its pretty close to stock weight.
all we have down here is an 1/8th mile track so im hoping to at least break into the 9's....hope they are still open so i can find out
Old Nov 13, 2004 | 09:57 PM
LT1guy's Avatar
Car: 1987 Trans Am
Was that on a Dynojet or a Mustang dyno? Last time on the dyno (Dynojet), Redraif's 3.4 did:
Max Power = 134.1 @ rear wheels (+20%) = 160.92hp @ the fly wheel
Max Torque = 207.4 @ rear wheels (+20%) = 248.88ft-lbs @ the fly wheel
Her HP is way lower than I would expect, but then again its with stock programming and I really think it needs a good valve job and more porting (heads are basically just cleaned up). It really needs better exhaust too. Still, the last time it was on the strip it ran in the mid 16s (the trans was acting up, not wanting to upshift), and spun off the line quite a bit on the Scorchers. I think it would probably run high 15s/low 16s as is with drag radials. BTW how much does your car weigh? The #s seem low to me for your car to do as well in the 1/4 as it does. Redraif's car is pretty heavy, probably heavier than my TA was stock.
Old Nov 13, 2004 | 10:27 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
"Redraif's car is pretty heavy, probably heavier than my TA was stock."
Well that red paint adds up, hehehe
Id think her car would / should run a low 15. You got plenty of mods.
Old Nov 13, 2004 | 10:34 PM
Car: 91 Camaro
those numbers were on a dynojet. i'm not sure what my car weighs exactly. i'm going to go get it weighed sometime, i just haven't done it yet. i worry more about the track numbers than i do dyno numbers anyways. but, yea, i would like to see my hp estimates backed up by a dyno sheet.
Old Nov 14, 2004 | 12:45 AM
Pillsbry10's Avatar
wow so my car's numbers were
133hp and 178 tq
ams car 3.1
143hp and 165 tq
Redriffs 3.4
134hp and 207 tq
so i guess my numbers really are pretty good considering the mods i have done, i cant wait to get my 3.4 in hopefully itll do much better than the 3.1
i couldnt get any track numbers for you guys as our track closed last weekend grrr, week to late
Old Nov 14, 2004 | 10:37 AM
Car: 91 Camaro
redraif's made 207 tq
you planning any trips to FL? our tracks are still open down here!
Old Nov 14, 2004 | 11:30 AM
Doward's Avatar
Actually, if Am91's car weighs around 3350 with him in it (You really need to weigh the car!) he should be ~175hp. I know my car weighs just under 3000lbs, and with my 200 lbs in it, I'm doing ~235hp.
And I have yet to do the new heads/intake and 1.6 roller rockers.
Old Nov 14, 2004 | 12:33 PM
Pillsbry10's Avatar
haha my bad, guess i cant read late at night, i edited the post.....if i had the money id love to come down to florida for awhile, its to cold to ride my motorcycle down here now(one reason why im sick) oh well guess i wont get any track times with the old motor
Old Nov 14, 2004 | 01:09 PM
LT1guy's Avatar
Car: 1987 Trans Am
There is a lot of extra weight in the car; tons of sound deadening, a heavier early disc brake rear, HEAVY wheels, bigger sway bars, extra equipment (wonderbar, strut brace, neon, stereo stuff), plus its pretty low, stiffly sprung (cut-down Eibach Pro Kit, so the rate is more than normal), and completely not set up for drag racing. She weighed it once (before the disc swap) and I want to say it was around 35-3600, and I don't think that was with her in it.
Hopefully by spring we'll have some of the tuning issues corrected, throw on some drag radials and skinnies, yank off the front swaybar, and see what it will do.
Funny though, it has tons of torque (for a V6), yet everyone said my cam selection was too big and would kill all the torque!
Old Nov 14, 2004 | 01:12 PM
LT1guy's Avatar
Car: 1987 Trans Am
Not sure, other than our annual trip to the Southern Trans Am Regionals in Ft Walton Beach in late March...unfortunately both of us have a lot less free time than we used to!
Old Nov 14, 2004 | 01:35 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
I have never weight my Camaro, but I would imagine it sits around 3100lbs. By the time i get into it (240lbs) and the wife and daughter (wife is 6' and about 155, duagther is 5'1" and about 105) that puts a total of about 3600 + a full load of fuel at around another 100lbs=3700lbs aprox.
There is a major difference in acceleration in this car between just me and a half tank compared to the family + full tank and we are only talking 300lbs- It fells like about a 1 1/2-2 sec drop in 0-70.
Weight is major in these cars.
I want to also add that I can not even begin to spin the tires in this thing- and barely spin them for a split second in the rain when taking off. But when this car was stock (years ago) with less power and skinny 15" rims tires w/no posi, I could roast the "tire" on this thing fairly easily. I can't believe you guys are having to try and "set this things up for drag racing". They are slow enough that a good set of tires will cure any wheel spin of the line 20 feet.
Old Nov 14, 2004 | 02:45 PM
LT1guy's Avatar
Car: 1987 Trans Am
The Scorchers seem fairly soft, but considering the car has 3.73s and a stall they aren't enough, at least not enough to take full advantage of the convertor. The car would drop several tenths just from being able to launch off the convertor.
Old Nov 14, 2004 | 05:33 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
What are Scorchers?
Edit: Nevermind, I found them- BFG's. They are as bad a Radial T/A's, Like an ice skating rink. They are made for "show" if your into colored tires. I would not recommend something like that for any kind of performance value.
Old Nov 14, 2004 | 05:46 PM
Camaro_nut's Avatar
Why not just get DOT drag tires? Better than those
stupid Scorcher BFG tires! Those ARE just for looks, BTW!
I have driven a car with them on. It feels like the
car is not gripping to the road, especially on turns!
Old Nov 14, 2004 | 05:55 PM
Car: 91 Camaro
what stall convertor does redraif have?
Old Nov 15, 2004 | 01:15 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
I'm well aware these tires are not designed for drag racing, but there were no spare drag tires laying around that day. Plus with the tranny acting up I was not going to press the issue and damage it. As far as the Scorchers being only for show... Well those must have been some worn out tires, or way skinny that you were experimenting on. Cause mine handle as well as Comp TAs and better then most other tires that have been on the car over the years. Have had them on the car since 99. Never had a traction issue as far as handling goes. Grips the courners in a serious way. I live on a curve road and play in the car quite often on the curvies. Even took the car out on a road racing track. It held great even in the rain. Wished it had stayed dry long enough to play on the skid pad. Oh well!
Old Nov 15, 2004 | 01:16 PM
LT1guy's Avatar
Car: 1987 Trans Am
That is what I said, if you'll read the post! They ARE on the car JUST FOR LOOKS, BTW! They wouldn't be my first choice, but they do pretty well for 95% of what they are used for (daily driving and shows).
Considering the car is a V6, it grips just fine except from a dead stop.
Old Nov 15, 2004 | 01:17 PM
LT1guy's Avatar
Car: 1987 Trans Am
Around 2700 I believe...its been a while.
Old Nov 16, 2004 | 01:14 PM
redraif's Avatar
Computer crapped out before I could finish replying to questions yesterday. It is a custom Convertor made by Neal's Racing in Snellville, Ga. He specked it out to the cam and mods done to the car.
Old Nov 16, 2004 | 03:06 PM
  #42
Car: 91 Camaro
that's cool. i have a 2200-2400 stall in mine. however, lately, 3,000 hasn't been a problem. i don't know what's changed but something has! one day, i had it up to about 3500 before it started to spin! i can't wait to go back to the track now!!!!
Old Nov 17, 2004 | 04:43 PM
  #43
redraif's Avatar
Hope you are not having problems with yours...would suck to have the tranny bust. I can't wait to get mine back to the track with some tires that stick and the tranny shifting properly...
Hey I noticed in a tread that you mentioned you had cut open a stock plenum to see what your could do to open up the air flow...I have considered getting mine extrude honed...you think that enough material could be removed based on your observations to make a difference? It's that or build a custom one as you are doing...
Also have you done anything as far as an upgraded fuel pump?
Old Nov 17, 2004 | 07:59 PM
  #44
Car: 91 Camaro
yea, i need a new tranny anyways. i'd hate for this one to go but atleast i'm already planning for a new one if this one does go.
i did cut open a plenum, if you want i can send you pics of it and measurements. there is a lot of material there that can be worked with but the opening of the ports by the plenum is actually smaller than it is where the top bolts to the middle. that's backwards for a good taper...velocity. i'm sure that you could make a difference but i just decided that it would probably be a little more feesable to just build a new one.
no, my entire fuel system is stock.
Old Nov 18, 2004 | 11:31 AM
  #45
redraif's Avatar
pics and measurements would be a blessing...
Here's my email address
redraif@yahoo.com
Thanks!
The reason I mentioned the fuel pump was its something we are debating about on mine right now. Esp since I went to the 3.4...I mean if you think about it you would upgrade a 305's fuel pump if you went to a 350...plus with it being modified... Wondering with your 6s numbers if it was an upgrade you did or were considering. Had not heard of many people doing a pump upgrade. LT1Guy did one on his stock 95 and notice it gave him a better track time.
Old Nov 18, 2004 | 12:42 PM
  #46
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
I have an A/C Delco '89 Vette fuelpump in mine currently. It is a much better unit with all metal intenals, not plastic inerts like our stock fuel pumps have.
Old Nov 18, 2004 | 03:45 PM
  #47
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I went to a 91 camaro 350 pump in mine.
I couldnt remember the year vette to get one from, so I stayed camaro and went 350.
Old Nov 19, 2004 | 12:38 PM
  #48
redraif's Avatar
Dale & vsixtoy... what is the flow rate on pumps? What kind of gain did you get? I think we are going with a mustang fuel pump. Much easier to get flow rates and a good variety of sizes to choose from. I know GM and Ford measure differently as well. I think Ford is Liters per hour? Not sure!
Old Nov 19, 2004 | 02:31 PM
  #49
Dale's Avatar
Engine: 350 S-TPI
No clue what mine flows. If I gained anything, I really didnt notice it as I was trying to find a problem in the car, not performance. Pump was not it, so I went to next issue.
BTW, nice to see you back on boards LT1 and Redraif
Old Nov 19, 2004 | 02:36 PM
  #50
Pillsbry10's Avatar
quick question....im sure most of you have read the mods im doing to my 3.4 is my stock pump gonna be ok for awhile?
