Roller rockers for 2.8L carbed v6
Old Nov 12, 2004 | 09:50 PM
ThUnDeR2005's Avatar
Car: 1990 Camaro "RS"
Engine: 355 TPI
Axle/Gears: 3.23 LSD
Hey guys I was going through and reading all the old threads about what you can do for V6 performance. Now the thing is, some of the "V6" is vague... because theres 2.8 mpfi, 2.8 carb, 3.1 fi and 3.4 fi.
My question is the title... anyone have a link to roller rockers for a 2.8L carbed car? is there even ones? I've looked on jegs, jcwhitney and summit and can't seem to find any.
Also does anyone know of any 4 barrel intake or performance heads? Links are most helpful because I just can't seem to find this stuff lol thanks
Old Nov 13, 2004 | 06:56 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i don't have any links handy but, crane makes roller rockers. edlebrock makes the 4 bbl intake manifold. there are no aftermarket heads available. as far as 2.8 car'b, 2.8 fi, 3.1, and 3.4...there are no differnces in roller rockers or things like that, they are all the same.
Old Nov 13, 2004 | 11:16 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
I have CompCams Magnum roller "tip" 1.52 ratio rockers and pushrods on my 2.8 right now under the stock valve covers. The 1.6 will not fit under the valvecovers unless you go to Fiero Alum covers. http://www.compcams.com/Technical/Cu...g/HTML/310.asp
They are sold as a kit through Summit racing which includes the rollertip rockers (1.52 ratio) and the pushrods for $148.39
I put these in on the new 2.8 crate motor before it was installed aprox 3-4 years ago.I have owned the car for about 8 years before that and this made a noticible differnce in power and smoothness. The car will rev higher quicker.
The kit # is CCA-RP1413-12
http://store.summitracing.com/defaul...3-12&x=14&y=11
I am going to Crane full roller aluminum rockers (1.6 ratio) on the new 3.5l motor I am building right now
Old Nov 13, 2004 | 01:24 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
3.5? you get a caddilac cts driveline?
Old Nov 13, 2004 | 07:21 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
3.31"stroke x 3.62" bore = 3.4L /204CI (Stock '93-'95 4thgen engine)w/ 5.7" rods, 8.9:1 CR
3.31"stroke x 3.66" bore = 3.5L / 209CI
w/ 6" rods, custom pistons & 10.3:1 CR
Old Nov 13, 2004 | 07:29 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
don't ruin it for me
thought you might of gotten ahold of one
kinda figure what you were doing, planning on turboing it?
Old Nov 14, 2004 | 05:14 AM
oil pan 4's Avatar
Car: 89 Firebird
crane makes some too.
I have the part #'s on my cardomain page for 1.5 and 1.6 ratio.
Old Nov 14, 2004 | 05:04 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
Transmission: 700-R4
It's possible to use this kit it fuel injection? If not, is thereanother one out there to use with the fiero valve covers....
Old Nov 14, 2004 | 05:53 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Yes. The tallest rockers there are are the Crane "gold" aluminum 1.6 rockers and even they will clear the taller Fiero valve covers.
Old Nov 15, 2004 | 02:37 AM
oil pan 4's Avatar
Car: 89 Firebird
I'm cheap so I'll just bang dents into my valve covers.
All I need is a piece of wood with a "dent mold" cut into it and I can hammer away.
Old Nov 16, 2004 | 11:39 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
best upgrade for carb heads, is to swap to FI heads.
1.6/1.3 carb
1.72/1.42 FI
Then slap on 1.52 or 1.6 rockers.
I have cat-pep 1.6 rockers on my engine. they do the job, but tick/rattle. And yes, they are adjusted right.
Old Nov 17, 2004 | 12:37 PM
Engine: 355 TPI
So fuel injected heads would give me some boost in car performance?
What about heads from a 2.8L HO fiero? I just seen some on ebay and was wondering if they would fit.
Old Nov 17, 2004 | 12:44 PM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Same head as the fuel injected Camaros
Old Nov 17, 2004 | 12:46 PM
Engine: 355 TPI
lol ok didn't know. But at least I learned something new
So fuel injected camaro heads eh. From the bad things I've read about the carbed v6 heads, i'd assume i'd get a decent amount of power out of these new heads? Maybe like 5-10 hopefully?
Old Nov 17, 2004 | 12:58 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Very possible. A Cam swap, 4bbl Edelbrock intake, and like a 390cfm Holley would do you some fun on top of a 3.4L motor!
Old Nov 17, 2004 | 01:09 PM
Engine: 355 TPI
Alright cool. I'll look into some heads. Are heads hard to install? Or do I just take off valve covers and the heads on my camaro, put those new ones on and put the valve covers back?
Old Nov 17, 2004 | 01:35 PM
Dale's Avatar
Engine: 350 S-TPI
any fuel injected RWD 2.8/3.1/3.4 have "the same head".
s10
camaro
feiro
I'm sure their are more.
I thought an 1985 would be MPFI? Its still carbed?
Heads are quite a bit of work. Were talking atleast a good saturday, if not a whole weekend. Take half your engine accessorys off. Manifolds off, intake, valve covers, pushrods loose. Distributor out. Make sure all the old gasket is off, and block is level, then start back together.
Old Nov 17, 2004 | 01:36 PM
MDv6man's Avatar
Car: 1983, 1986
Essentially... just re[place the head gaskets and make sure that the surfaces are clean. Also adjust the valve lash. Consider a valve job before installation.
Old Nov 19, 2004 | 12:22 AM
Engine: 355 TPI
Sorry... my lil thing on the side isn't updated right, its an 1984 not 85 camaro.
As for head installation... hmmm... thats gonna suck... maybe I can go over to a friends house to do it (mostly because I can't do major repairs at home due to lease contract BLAH)
As for finding these heads... its freaking tricky! Ebay has some but i'm not a fan of buying used from someone I don't know. I can't seem to find any from a major distributor of car parts. I checked thirdgen classifieds and no luck.
I'll keep searching over and over tho... maybe i'll get lucky
Old Nov 19, 2004 | 02:28 PM
Dale's Avatar
Engine: 350 S-TPI
newspaper
local salvage yards
car-part.com
Check them. Like I said, s10 2.8 TBI, camaro, bird and a few others.
Old Nov 20, 2004 | 04:18 AM
oil pan 4's Avatar
Car: 89 Firebird
The s-10 heads and camaro heads are not the same.
They will bolt up and sawp no problem.
back in the day when I had a long block from a 2.8L TBI s-10 in my car I could see that the heads are not the same.
The MPIF heads have a vane cast into the bottem of the intake runner of the head. The TBI head clearly did not have that vane.
Old Nov 20, 2004 | 04:34 PM
Dale's Avatar
Engine: 350 S-TPI
all information I have found say TBI heads are same as MPFI heads.
My 93 s10 2.8 TBI heads look exactly like the 91 3.1 heads I have sitting in storage. The s10 heads had the vane in them also.
In fact, about a year ago when I pulled my s10 engine out, I posted a question here asking what that vane was, and why it was their.
Old Nov 20, 2004 | 07:18 PM
oil pan 4's Avatar
Car: 89 Firebird
I had heads form an '89 and they did not have the vane in them.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
