Problem?
Old Nov 16, 2004 | 01:45 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Problem?
I noticed today that if i am just cruising and i stump it to the floor my car seems to backfire threw the intake into the airbox, at least it sounds that way. Now i have heard of this before being a loose timing chain, however, i did take the dist cap off and see if the rotor turned it, moved a little but nothing big. I also heard this problem when my TPS went bad. (I orginally had a problem with hesitation, but it turne dout to be bad plug wires, so it fixed it, but i did replace the tps, then that new one went bad and but back the orginal one. I'm wondering if that could do it?) The other thing i heard was valves could be loose? Whats the most common fix to this, or should i not worry about it for now? Thanks
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
