Diameter of underdrive pulleys?
Old Nov 21, 2004 | 01:53 PM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
Does anyone know how much the diameter is decreased from the stock crank pulley to an underdrive pulley for our cars?
I know it was said that if you buy an underdrive crank pulley you decrease your stock belt size by 2 inches. I can figure out the diameter using this information fairly easily but it would just be an approximation so I was hoping to get a reasonably exact diameter value.
Old Nov 21, 2004 | 02:45 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
i'd like to know this too
Old Nov 21, 2004 | 04:42 PM
Axle/Gears: 4.10
Anyone know the answer to this??
I was messing around with some math and estimated that the belt was on 2/3 of the stock pulley and assumed it would also be on 2/3 of the underdrive pulley. My calculations revealed that the new diameter should be 5.04"
Anyone know if this is remotely correct?
Old Nov 21, 2004 | 05:48 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Outer most lip diameter of the stock pulley is 6 1/2"
The ASP underdrive pulley is indeed 5"
Old Nov 21, 2004 | 06:26 PM
Axle/Gears: 4.10
Thanks a lot vsixtoy. Is the outter most lip of the ASP underdrive pulley 5"?
Old Nov 22, 2004 | 01:39 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Yes.
Old Nov 23, 2004 | 09:45 AM
Axle/Gears: 4.10
thanks a lot
grngryoutmyway
Oct 18, 2016 05:48 PM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
