~ Accel 17lb./hr Fuel injectors for a 2.8 ~
Old Nov 21, 2004 | 03:48 PM
Slow2.8's Avatar
So I want to replace all of my stock injectors with new ones so i'm debating whether i should get these accel 17/hr. I know that that some people have put 3.1 injectors on a 2.8 with no problem so I shouldn't have a problem with mine. Only thing is i have heard some bad stuff about accel fuel injectors, mainly the 26 so i'm looking for other options on what i should do. Heres the link to what i want to get, if anyone has them let me know if you like them or not. http://store.summitracing.com/partde...l+injectors+17
Old Nov 21, 2004 | 04:44 PM
LT1guy's Avatar
Car: 1987 Trans Am
Lots of people here will get the used injectors of their choice and send them to Rich at Cruizin Performance. he'll clean and flow test them so they're good as new. this would probably save you at least $150 over the cost of the Accel injectors. If cost isn't an issue, they'd probably be fine.
Old Nov 21, 2004 | 04:47 PM
Slow2.8's Avatar
Ya the cost isn't an issue right now, i'd figure i'd save time finding the injectors that i want, the 3.1 ones from a junkyard, and the downtime of my car for a while. Hopefully they'll perform as good as the ad says -- but you never know until u put them in.
Old Nov 26, 2004 | 01:03 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
13 is stock 2.8 15 is stock 3.1
unless your modded i think you might be going a bit big
Old Nov 26, 2004 | 12:20 PM
Slow2.8's Avatar
I just ordered the 15 lb/hr. to be on the safe side, they should be arriving shortly
Old Nov 27, 2004 | 01:22 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
should be finewith them
Old Nov 27, 2004 | 03:09 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
13 is not stock for the 2.8. Read this thread (also started by Slow2.8):
https://www.thirdgen.org/techbb2/sho...hreadid=268057
Further proof is the flow test on my 2.8 injectors from Cruzin Performance, which averaged 15.45pph.
Old Nov 30, 2004 | 12:46 PM
82-T/A [Work]'s Avatar
Some 2.8s came with 15s, but most came with 13s.
Actually, the 15s are more like 14.6 to be exact.
I currently use 17 pound injectors on my 87 automatic Fiero. I rebuilt my 2.8 with a 3.1 crank and rods. It actually runs quite well, but I get kinda crappy fuel economy.... then again, I don't use it as a daily driver.
Make sure if you get new injectors, you get the pintle style ones.... those are much more efficient than the disc style ones.
Old Nov 30, 2004 | 04:10 PM
Slow2.8's Avatar
I just got the 15lb/hr. on the car, runs good, and ya there the pintle style ones.
One problem, car still takes a few times to turn over to get to run...now this happens when i turn off the car and try to start it again, before it would happen after a few hours (usually overnight)??? Going to check the fuel pressure again, but now i know it's not because of leaking fuel injectors.
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
