Cold Air = Very Yes.
Old Nov 27, 2004 | 01:02 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
heh. 2:15am, and I'm out tuning, in 40 degree weather. OMG. THE PULL IN 3RD GEAR IS AMAZINGLY MORE POWERFUL THAN WHEN IT'S HOT OUT.
Of course, some of that, could simply be that I'm too freaking rich. I really got to save up for a WB O2.
Old Nov 27, 2004 | 01:22 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
anytime i drive when its cold my car has some haul.
i wonder how hard it would be to make a cooler for incoming air
Old Nov 27, 2004 | 02:54 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Me too.
Old Nov 27, 2004 | 05:47 AM
Jerriko 3.4's Avatar
Car: 1987 Firebird Formula
Engine: 3.4L 207 V6
Transmission: T5 W/C
Ahem.
Old Nov 27, 2004 | 08:58 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Ya build a pocket for the inter cooler to hold blocks of dry ice.
Old Nov 27, 2004 | 11:59 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I know it doesn't make sense, but I feel like it's the other way for my car. The hotter it is outside, the faster the car seems to run.
Of course I love the heat- the hotter the better- and I usually have the music up and the windows down... so I guess it's all psychological, huh?
In the cold (which I hate), my car doesn't wanna move.
Old Nov 27, 2004 | 12:19 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
maybe the cold affects your slush box Tom???
Mine loves the cold.
Old Nov 27, 2004 | 01:25 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
this actually isn't too bad of an idea
Old Nov 27, 2004 | 02:18 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
dry ice should be easy to find. and it might also help cool the motor down if the inter cooler is in front of the radiator.
Though it would work the best if the cooler air was detected by the computer sensors. Not sure where D has the ITA or MAF hooked up.
Why simply putting a bag of ice or even a block of dry ice on the intake may not be as helpful in an FI car like it does a carb'ed.
Old Nov 27, 2004 | 02:27 PM
92RSSlowmaro's Avatar
When its cold, mine sputters under hard acceleration (until the engine is warm). Time for some new spark plugs.
Old Nov 27, 2004 | 02:55 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
mine does the same thing, I just figured it was too friggin cold to be trying to go quick... it's more when I start it, sit for 30seconds and go cause I'm friggin late for work.
Old Nov 27, 2004 | 05:52 PM
Doward's Avatar
Oh, no guys, don't misunderstand me - I always let my car reach operating temp before running around. I've got a really good CAI setup for the turbo - I gotta get more pics eventually. Hey, maybe I'll get Am_91 to take a quick couple of clips of the car, when I come up to have him coat my intake pipes!
Old Nov 27, 2004 | 07:58 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
Could we have freon from the a/c lines run into the bottom of the throttle body where the coolant usually flows in? That stuff is usually cold isn't it? I imagine that would cool the air coming in a bit if coolant running there heats it up enough to cause a difference....
Old Nov 28, 2004 | 01:36 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
I would try the TomP tuneup
do a search for it a lot of ppl have good luck doing it
Old Nov 28, 2004 | 01:37 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
a lot of the cooling that comes from freon is because of the compression expansion stuff it goes through
and the compressor would prolly eat up more power then you would gain from the air being cold
Old Nov 28, 2004 | 01:42 AM
I think TomP is quite aware of the TomP tuneup
Old Nov 28, 2004 | 02:43 AM
Damn, you stole my line!
Old Nov 28, 2004 | 02:54 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
lol theres a blonde moment
Old Nov 28, 2004 | 07:46 AM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
Transmission: 700-R4
Does anybody have tried about a intercooler,just like an 18 wheeler or a turbo setup without the turbo.Will that help?
Old Nov 28, 2004 | 08:42 AM
Doward's Avatar
Nope. You can't cool the incoming air charge any more than ambient air temp. Now, if you employ activ cooling (dry ice) then you might get somewhere.
Old Nov 28, 2004 | 02:20 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
anyone ever notice that the car has more pickup right after you put gas in it on a hot day?
ive seen dirt track cars have gas line coolers the kinda look like a champaigne ice box only with gas lines coiled in it. fill with ice.
Old Nov 28, 2004 | 06:49 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
yea, whenever you bring it for me to coat the pipes, i'll shoot some video of it! speaking of that...when you gonna bring it for me to coat the pipes?
Brinkkl2000
Aug 4, 2018 08:29 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCtometal
Sep 2, 2015 02:01 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
kyle5647
Aug 15, 2015 11:56 PM
