Turn indicators no worky, advice?
Old Nov 27, 2004 | 05:15 PM
92RSSlowmaro's Avatar
When I did my clutch, I accidentally crushed a few wires between the bell housing and the block. They were the wires that lead to the transmission.. im guessing one is for the VSS and one is for the shift indicator. Ever since that happened, my turn indicator fuse blows when the car is running and the turn signals are on. Could there have been a wire around there for the signals? The bulbs work fine BTW, there is just a short somewhere. I really hate to pull the trans+bellhousing back to rescue the wires... any way I could make a splice? When it is light outside I will try and get some pictures of what i'm talking about.
Old Nov 27, 2004 | 09:59 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The back-up lights draw power from the same fuse; if you crushed one of those wires (blue and/or green) it is grounding out, that is the problem.
Old Nov 28, 2004 | 08:07 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
yep, theyre on the same circuit. i couldnt figure out why my turn signals kept blowing fuses. after a while i realized that once it happened, my reverse lights wouldnt work either. did some checking and found that my reverse switch was bad and grounding.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
beast94
Aug 20, 2015 06:44 AM
djmarch
Aug 19, 2015 12:07 PM
Bryan F
Aug 18, 2015 02:28 PM
