cold start problem
Old Nov 30, 2004 | 03:39 PM
red450ih's Avatar
Car: 86 FBird
Engine: 173
cold start problem
Hello, I'm new to this board. I've got an '86 Fbird with 2.8/700r4. It has had a cold start problem for quiet some time. It will not idle when cold and RPM fluctuates while in park if it does idle. After warm up, all is well. Checked for codes, none showed up. I replaced the IAC to no avail. What else should I be looking for/at?
Thanks,
Keith
Old Nov 30, 2004 | 03:40 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
check your egr system, and welcome to the boards
Old Nov 30, 2004 | 04:21 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
My '87 camaro had the same problem. Hard to start and then fluctuates until warm. I had a bad Intake temp. sensor (no code showing). It was telling the ecm that the air coming in was 180 degrees. Check the resistance of the sensor. Should be around 3500 ohms when cold (70 degrees) and gets lower as it gets hotter, mine was 300 at 70* which would actually be 180* if it was accurate.
I also replaced the coolant temp sensor in the intake manifold underneath the throttle body, just in case that was bad or misreading.
I also had a vacuum leak at the pcv valve.
Now it runs great. It was 29* this morning and it started right up and the idle was smooth.
Old Nov 30, 2004 | 04:31 PM
red450ih's Avatar
Car: 86 FBird
Engine: 173
Thanks fellas, I'll give those a try and see how she does. It's been like this for several years. It's also a second car and is not driven everyday.
Thanks again,
Keith
Old Feb 22, 2005 | 03:24 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I am having a similar problem but with a 305 TPI what will the EGR system have to do with it. The only reason I am asking is because i dont want to take off my TPI unless I have to, its not fun.
Old Feb 22, 2005 | 06:13 PM
bru333's Avatar
Car: 1987 Camaro SC
The EGR can get stuck open. Acts the same as a vacuum leak at idle.
Some other posts have said that cleaning the throttle body and IAC has cured this problem.
Old Feb 22, 2005 | 09:15 PM
Engine: 388 Carb
Axle/Gears: 4.10
Is there a way to pinpoint the EGR problem or is it trial and error, (money pit?)
Old Feb 23, 2005 | 07:58 AM
KED85's Avatar
That's my problem, too.
I haven't changed the Intake sensor yet.
I will shortly.
Also suggested is to replace the IAC, same time?
Will the running poorly engine at start up, will it destroy a Catalytic converter? My converter is now hallow due to the innards fell apart and flowed to my muffler, causing blockage. Discovered when I replaced the muffler other day.
92camaroJoe
Jul 29, 2023 07:57 PM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
