Stumbuly idle and check engine light if idling too long?
Old Jan 10, 2005 | 02:25 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
Idle was somwhat rough befor tuneup and got worse after. I also get a check engine light if the car idles for more than a minute or two?
Old Jan 10, 2005 | 02:50 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Pull the codes and let us know what it's showing it thinks the error or fault is....
Old Jan 10, 2005 | 06:11 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
I dont know where the diagnostic plug is on a 92 camaro. Not in the same place as my Iroc!
Old Jan 10, 2005 | 11:03 PM
BitchinRS's Avatar
Should be. Look under the stearing wheel. You may be one of the "lucky" who still has the cover for it. If you are sitting in the drivers seat it should be just off center to the right of the stearing collum.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
