Datalogging the MAF cars
Old Jan 13, 2005 | 11:27 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Anyone know what programs I can use to make it happen? Car is an 86 model lb8 maf. I have acces to everything to tune now, ALDL from Moates, as well as the burner and various software. Let me know, I just want to get a data log for now. I can get the definition files for this car, so I know it can be logged SOMEHOW.
Old Jan 13, 2005 | 04:34 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
..... your answer is in another ACTIVE thread....
https://www.thirdgen.org/techbb2/sho...hreadid=274594
Old Jan 13, 2005 | 05:37 PM
FbodTrek's Avatar
Didn't answer any questions Fine for 3.1 guysm what about me?
Old Jan 13, 2005 | 05:42 PM
TechSmurf's Avatar
Engine: LS1, Scrap
Originally posted by TechSmurf
So far as I have found, the 7302 guys are stuck using Diacom and TunerCATS. Supposedly WinALDL will work with the 2.8s, but I haven't gotten it to communicate quite yet (haven't tried very hard either, though)
Originally posted by Doward
'302 uses WinAldl, but you have to ignore the data coming through - it reads it fine, but screws up teh conversion.
I've been using the RAW output, and converting myself!
Old Jan 13, 2005 | 05:45 PM
FbodTrek's Avatar
So what that's telling me is that Win ALDL MAY work.....but that's it? Not very helpful. I thought people had tuned these before?
Old Jan 13, 2005 | 05:55 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
I have heard that this version will work on all of the 2.8 MPFI's as well meaning the 7302's
http://winaldl.joby.se/
Old Jan 13, 2005 | 07:11 PM
TechSmurf's Avatar
Engine: LS1, Scrap
No, what that says is Doward uses WinALDL, and to my knowledge Doward is the only person I know of who has done anything with the 7302 (RBob might have too, but I'm still fuzzy as to what RBob even drives)
Old Jan 13, 2005 | 07:36 PM
RedTtop5spd's Avatar
Car: 99 SS
I have had WinALDL work on my 85 2.8. It does work. You just need to pick the right ecm for it. I think the readme file or something of the sort that comes with it says which file to use with which engines and years. Little slower logging than I want, but it does work.
Old Jan 13, 2005 | 10:36 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
It's listed as a '85 ECM and an '86 ECM.
The '88 (my car) uses a different datastream than either - the LV8 value is listed under MCUIO, for example.
Old Jan 14, 2005 | 07:16 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Some days he's not sure either
RBob.
Old Jan 14, 2005 | 01:47 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Why can't ya just use the laptop as the cars computer??? run some virtual ecm program, adjusting on the fly as the speed of the laptop CPU. Some kind of virtual program like making a mac run windows stuff. The cars stuff thinks your laptop is the stock computer.
Old Jan 14, 2005 | 02:27 PM
TechSmurf's Avatar
Engine: LS1, Scrap
You can... but personally, I don't want my car crashing every 30 minutes.
Old Jan 14, 2005 | 05:48 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
run the stuff in dos
Old Jan 14, 2005 | 05:50 PM
TechSmurf's Avatar
Engine: LS1, Scrap
I think I'll stick to the hardware that's designed to run the system.
Old Jan 14, 2005 | 10:01 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
(this is FbodTrek) What if I have that weird 870 ecm?? Cause that's what it is... WHat chip burner/reader can i use to pull the BIN? I've looked all over, and I can't find anything but how to convert it to 730, which I won't do. How would I go about pulling a data stream, and about reading the PROM?
Old Jan 14, 2005 | 10:04 PM
Doward's Avatar
I'm too lazy to look it up... refresh me on what the '870 is used on?
Old Jan 14, 2005 | 11:20 PM
Car: 99 SS
The 870 is used on 85 and some of the 86 2.8's. It's the red headed step child of Chevy ecm's.
Old Jan 14, 2005 | 11:51 PM
Doward's Avatar
Someone here swapped a '870 with a '302 ecm, I believe, with no differences.
The ALDL datastream is defined differently, though.
Old Jan 15, 2005 | 02:00 PM
Car: 99 SS
I believe that was Project: 85 2.8 bird.
specialized
Jun 18, 2022 09:26 AM
Fast355
Dec 2, 2016 06:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
NBrehm
Aug 25, 2015 11:49 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
