Distributor
Old Jan 20, 2005 | 09:18 PM
TVRPAUL's Avatar
Engine: 3.4lL 60* V6
Transmission: Tremic TKO 600 RR
Distributor
Are there any after market distributors for the 60* V6 what would work on the 3.4 crate engine I am putting together with a carburettor. Mallory in there tech section someone asked them almost the same question for a 3.4 crate.they told the person the Unilite electronic distributor p/n 4569201 would be a good performance package. When I look the p/n up with summit racing the list this distributor for the 90* V6, any thoughts or am I stuck with a stock distributor for this engine I am putting together.
Thx.
Old Jan 22, 2005 | 12:24 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If you're keeping a factory computer in there, then there's no aftermarket distributors available. Just rebuild yours with a brass cap/rotor (if you're getting a high-voltage coil) and an aftermarket spark module.
Or you can buy a new "factory replacement" distributor, but it won't be a performance one, it'll just be newer.
If you're ditching the factory computer and going with a carb, then you can use the Mallory distributor. Go to Mallory's web site and look up the part #, or just call Summit 800-230-3030 and ask them to look it up.
Old Jan 22, 2005 | 01:48 PM
TVRPAUL's Avatar
Tom re distributor
Thanks Tom, there will be no computer on the 3.4L, and going with a carb. Last night I found a listing for a Mallory for the engine p/n 4769201, a bit pricey but if you are going to do something do it all the way.
By the way I am in Englishtown NJ, where are you??
Paul
Old Jan 22, 2005 | 04:52 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Sounds like you got a good project going there..what cam are you planning to run?
Old Jan 22, 2005 | 05:29 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
go BIG and get the magneto for the 2.8~3.4
Old Jan 22, 2005 | 06:28 PM
TVRPAUL's Avatar
I am staying with the cam that comes with the 3.4, the one made by crane per. GM Performance. Now would some one educate me as to why I should put in a magneto (sp?)
Paul
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
