enigine upgrades?
Old Feb 14, 2005 | 04:55 PM
  #51
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
damn, I'm only getting like 10 - 12mpg if I'm lucky. That's so sad. I could put a 350 in and get better gas milage over my v6
Old Feb 14, 2005 | 05:07 PM
  #52
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
I get about 15mpg in the city, and 20 highway... if I'm lucky
REBUILT MOTOR, new wires, new coil, new plugs, new EGR, new air filter, new oil/filter, new fuel filter, new distributor cap, and a brand new computer...
I cannot think of why I'm not getting anywhere close to the suggested MPG of this vehicle....
I cruise on the highway at 85ish at about 2300-2500 rpm.... seems mighty low... in fact, my mileage almost doesn't change from 2000-2800rpm... 70mph to 100mph.... very strange to me.
Old Feb 14, 2005 | 09:48 PM
  #53
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Check Tire Pressure
Get Fuel System Cleaner
Old Feb 15, 2005 | 09:47 AM
  #54
ScrapMaker's Avatar
I wonder if my catylitic convertor could cause this?
what about people who take apart their intakes and clean the carbon out, does that make a huge difference?
I just calculated my mpg on the highway as being 16mpg yesterday.... that's absurd!
Old Feb 15, 2005 | 03:21 PM
  #55
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Hmmm...many people on this board say their mileage is down big time to what they should be getting,including me.I get about 210 miles per tank...Pretty Horrible....I gave up looking for the problem.A clogged cat will cause lose of power and economy.Check it out.I replaced my entire exhaust with Dynomax and Magnaflow high flow cat.Yet no increase in MPG.
Old Feb 15, 2005 | 03:27 PM
  #56
ScrapMaker's Avatar
I was just thinking... if the intake was clogged with carbon, wouldn't you simply lose power, but get better mpg, since you can't burn as much fuel? or are you just going to be putting more unburnt fuel into the exhaust?
Old Feb 15, 2005 | 03:37 PM
  #57
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
I doubt it would be clogged so much it would actully prevent air from entering the engine.
Old Feb 15, 2005 | 05:16 PM
  #58
ScrapMaker's Avatar
by clog, I mean restrict. not completely blocking but lessening the overall available air to the engine... wouldn't that actually lower power output, and also gas input?
Old Feb 15, 2005 | 06:07 PM
  #59
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
I thought gas was controlled by how open your throttle body is, not by the actual amount of air coming in. If that's the case then that'll just dump too much gas into the intake unless there's something I don't know which I'm sure there is all kinds I don't know.
Old Feb 16, 2005 | 09:45 AM
  #60
ScrapMaker's Avatar
isn't that what the MAF is for? if you are getting less air, your computer knows and adjusts fuel settings.
Old Feb 16, 2005 | 10:24 AM
  #61
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
We dont have MAF's
Old Feb 16, 2005 | 10:25 AM
  #62
ScrapMaker's Avatar
there is some sensor in the air filter area, I'm sure of it
some air flow sensor of some kind
Old Feb 16, 2005 | 10:42 AM
  #63
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
It's the Air Temp sensor
Old Feb 16, 2005 | 01:46 PM
  #64
ScrapMaker's Avatar
can't the MAP sensor tell you have lack of air, because the pressure in the intake is lower?
Linson
Oct 24, 2025 02:00 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
Zell1luk
Sep 29, 2015 10:36 AM
dbrochard
Sep 25, 2015 04:56 PM
