View Poll Results: Any interest in mandrel bent Y pipes?
Yes
66.67%
No
33.33%
Voters: 6. You may not vote on this poll
Mandrel bent Y pipes for stock exhaust?
Old Feb 8, 2005 | 09:23 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Is there any desire for a mandrel bent Y pipe for the stock exhaust manifolds?
I'm just curious... looks like I could build them for about $150-$175 each.....
They'd be worth a solid 5-10hp, over stock - more if you have a catback!
Also, Feb25th starts the Turbo Group Buy In - I'll have more details on the 11th
Old Feb 8, 2005 | 09:27 AM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Sure..
Is it a bitch to install?
Old Feb 8, 2005 | 09:47 AM
Doward's Avatar
No, it'll be easy
Old Feb 8, 2005 | 01:29 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
you dont have anything for the pacesetter headers do you? last i heard you didnt, just wanted to make sure. im hoping to get in on the buy in, but that would be one thing that stops me. well that and how much i get back from taxes, lol.
Old Feb 8, 2005 | 01:31 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Originally posted by Doward
No, it'll be easy
How much would a place charge me to have it installed? Does it require taking off your entire exhaust?
Old Feb 8, 2005 | 02:20 PM
Doward's Avatar
If a shop charges you more than $75, burn the place!!
Old Feb 8, 2005 | 02:40 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
I have the Dynomax Catback,would it work better with a high flow cat?
Old Feb 8, 2005 | 03:50 PM
LinuxGuy's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TBI
I don't really see the point...
PaceSetter Headers and Y-pipe are only approx. $210. For $35 to $60 more than this $150-$175 mandrel-bent y-pipe, you'll get headers as well.
Old Feb 8, 2005 | 04:18 PM
Doward's Avatar
This is true... I may have to rethink this!
Old Feb 8, 2005 | 06:41 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
Do you have a shop that does mandrel bent pipes? I can't find one around here. I will need a decent system run on my S10 one day.
Old Feb 8, 2005 | 07:01 PM
Doward's Avatar
I build 'em myself
Old Feb 8, 2005 | 10:44 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Reduce the price to $100
Old Feb 14, 2005 | 03:49 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I bought my mandrel-bent y-pipe back in 1996; made by AP, cost was $180.
Old Feb 14, 2005 | 04:39 PM
Doward's Avatar
So I wasn't so far off Any increase over stock?
Old Feb 15, 2005 | 01:27 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
(laughs) Beats me, actually; I installed a ton of things all at once! That's actually been a bummer... people used to ask me "did the ADS superchip make the car feel stronger" or "how did the spark coil help" and I couldn't answer 'em. But it sure as hell can't hurt. One note; the stock Y-pipe is double-walled, the aftermarket one I bought (and any pipe that would be manufactured by anyone) is a normal single-wall pipe, so the exhaust does get a little bit louder.
Old Feb 15, 2005 | 01:35 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Didnt you mention.You put the Stock PROM back in and the car performed the same as it did with the ADS Chip?
Old Feb 15, 2005 | 01:54 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep I did, but I didn't know that until around the year 2000 or so. I replaced a ton of parts all at the same time (my second restoration) in 1997.
Old Feb 15, 2005 | 03:38 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Where can I get a Y-Pipe made or where can I buy it?
Old Feb 16, 2005 | 10:35 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I bought mine at a real auto parts store (not Pep Boys or Strauss or those other fake "glitz" stores), the kind with the concrete floors and dirty counters and greasy parts books.
Old Feb 16, 2005 | 11:15 AM
Doward's Avatar
Any exhaust shop should be able to build you one, but it'll be crush bent.
Autozone and Advance, DO (IIRC) stock the Y pipe, but it's like $160, and it is crimp bent.
Hence why I'm asking if any demand to build one for the stock setup, mandrel bent
Old Feb 16, 2005 | 04:34 PM
Supermann's Avatar
Car: '86 Camaro, '85 Z28, '92 Firebird
Engine: LB8 2.8, LG4 5.0, LO3 5.0
Transmission: TH-700R4, T-5, TH-700R4
Axle/Gears: 3.42s, 3.23s, 2.73s
I had thought that the pacesetter headers were priced somewhere in the $300 range. Has that changed? Cause I mean this y pipe would be a heck of a lot cheaper than that.
Old Feb 17, 2005 | 03:57 PM
LinuxGuy's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TBI
As I said above: "PaceSetter Headers and Y-pipe are only approx. $210."
Painted headers & Y-pipe:
http://store.summitracing.com/partde...6&autoview=sku
Summit P/N: PSM-70-1206 -- $208.39
Armor Coated Headers & Y-pipe:
http://store.summitracing.com/defaul...=KeywordSearch
Summit P/N: PSM-72C1206 -- $293.99
Info from Summit Racing:
Header Material: Steel
Header Finish: Painted (PSM-70-1206), or Armor Coated (PSM-72C1206)
Header Style: Shorty
Primary Tube Diameter (in): 1 1/2
Collector Diameter (in): 2 1/4
Equal Length: No
Primary Tube Gauge: 16-gauge
Collector Attachment: 3-bolt flange
Flange Style: Standard
Flange Thickness (in): 3/8
Bolts/Studs Included: No
Gaskets Included: Yes
Reducers Included: Yes
Y-pipe Included: Yes
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
transaero
Aug 31, 2015 01:14 AM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
