Gave my V6 sorta of the works
Old Feb 17, 2005 | 01:58 PM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
I tried fixing my camaro since it gave me a code 45. I basically changed the mufller, the catalytic converter, O2 sensor, egr valve, air temperature sensor, temperature cooling sensor, new ac rapid fire spark plugs, spark plug wires, replaced o-ring from distributer and changed the distributor cap & rotor. And if this list doesn't stop, well it keeps going, well my mechanic did most of the work since im going to school and i dont have time to work on it, but anyways, then my motor had an air leak, by the manifold and the radiator had a crack. All these problems were fixed but my camaro still shakes. I know this seems to be like an essay, but its what it was done to my camaro, any suggestions or should I explain again?
Old Feb 17, 2005 | 02:00 PM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
I would like to add that the gaskets from the manifold were changed and the radiator had a crack and fixed that problem at a radiator place.
Old Feb 17, 2005 | 03:16 PM
RedTtop5spd's Avatar
Car: 99 SS
When exactly is it shaking?
Old Feb 17, 2005 | 04:49 PM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
I guess the whole car. My mechanic called me a while ago. Said something about the full throttle body and some other sensor.
Old Feb 18, 2005 | 10:10 AM
MakeitQuick92RS's Avatar
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
Clean the throttle body.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
rudolphschenker
Sep 4, 2015 02:41 AM
