2.8 oil leak
Old Feb 8, 2005 | 11:20 PM
CamaroKid89RS's Avatar
Car: 89 Camaro RS/SS
Axle/Gears: 10 bolt with 3.42
2.8 oil leak
I was wondering if anyone knew if there are common leak areas on these engines. I thought it was the rear main seal, but when I changed the oil I noticed the oil was coming from somewhere above that, thus leaving that out of the question. Also taking ideas on an engine swap of some kind if anyone wants to offer some helpful information.
Old Feb 8, 2005 | 11:41 PM
KED85's Avatar
My swap guide for putting a 3.4 under the hood should still be around.
I recently discovered the rear cam seal was a big leaker in my 3.4.
When I changed the engines I installed a new rear main seal.
Add to the list the distributor seal, that's one big leak area, also.
Old Feb 8, 2005 | 11:47 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
I go through oil pressure sending units like they are going out of style. I don't know if its maybe because of the full synthetic oil I run seeps through the seems or what. (Drivers side of motor just about the filter. Drips onto y-pipe exhaust)
Old Feb 9, 2005 | 12:40 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Sounds like another case of distributer o-ring gone bad. That is very common on these cars. Take a good look around the base of the distributer and see if there is oil puddling up there. If not there, it probably is your camshaft plate gasket.
Old Feb 18, 2005 | 08:07 PM
I found it
Turns out the problem was that the person who owned it before I did decided not to put the bracket that holds the distributor back on and siliconed it instead....after several hours of jury rigging some other clamp, it now works again.
Old Feb 18, 2005 | 08:21 PM
KED85's Avatar
Sounds like you had a real fun experience.
Oh joy!
Good on the results, tho!
Old Feb 18, 2005 | 08:22 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Re: I found it
Shoot me a pm w/name & addy. IF I still have the hold down bracket from the 2.8/3.4 I'll mail it to ya.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
rjcme
Sep 5, 2015 01:23 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
