high idle
Old Feb 14, 2005 | 01:31 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
high idle
My car tends to rev up to 2500rpms when in parked after driving for a while sometimes. ive tried to lower the the idle and it still does this. I read somthing about cleaning the TB and the IAC. If this is true how do I do it and what is my problem right now? Note: intake mainfold has been sealed recently, along with me instaling new vacum lines.
Old Feb 15, 2005 | 06:09 AM
oil pan 4's Avatar
Car: 89 Firebird
Make sure you don't have a vac leak.
You can clean the TB by sparying carb cleaner onto it while it is running, do the same to the IAC passages.
Old Feb 15, 2005 | 01:18 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
And you can also remove the IAC valve and clean it by hand...and pull the tube off the intake and clean the TB with a rag and TB cleaner by hand, with the engine off of course....that always works better for me cause I know I'm getting it fully clean.
And also, while you have that TB cleaner in your hand...put everything back together, fire her up, and start squirting the cleaner around all your vacuuum hoses, your intake gaskets, your tb, IAC valve, fuel injectors, etc....any potential source of a vacuum leak. Don't HOSE THEM down, but make it so if there is a vacuum leak, the cleaner vapor will be pulled in and combusted, which will make the engine's idle spike for a quick second.
Old Feb 15, 2005 | 03:41 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
How exactly do you clean a throttle body?Just spray the **** and wipe it off?
Old Feb 15, 2005 | 09:12 PM
Nixon1's Avatar
Yeah dude just spray the throttleblade and opening around the blade and clean it with a rag. Repeat as necessary until rag is coming out clean and the blade is nice and shiny! It's easy...just wrap the rag around your 2 fingers and have a buddy hold the gas pedal down for you...or use your free hand to hold the blade open, whichever is more convenient.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
