Smog Pump Deletion
Old Mar 7, 2005 | 05:02 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Smog Pump Deletion
Few questions:
1.Is delete pulley necassary? Route belt bypassing pump possible?
2.How much HP does smog pump actully drain?
3.Will anything else malfunction? EGR or SES Lights?
Old Mar 10, 2005 | 09:15 PM
vortex's Avatar
Car: 95 Mustang GT Vert
Engine: 5.0
Hey, sorry im the help you get, seeing as im from the other "stable" but working on Doward's car, no, we didnt need a pulley for removal.. you just need to alter your belt size.. (sorry dont know the number off hand.. but just wrap some string around the pullies in the correct order, and then subtract 1-2 inches for the tensioner, and then work from there. either way, keep the number, for when your belt wears out.
2.) Removal of the smog pump may not even show a diff on the dyno, but does remove parasitic drag on the engine which (again not much) helps engine rev a little freeer (more free, less non-free?) and, since the smog pump adds air into the cats to help emissions, you can remove cats (in certain areas) as well to help, freeing up your exhaust and belts/engine, you may get a couple of hp, maybe in the 5 range?
3.) again, not the bloke for this question, but i believe it depends on the year, OBD I shouldnt, OBD probably will.
hope this helps. cheers
Old Mar 10, 2005 | 09:57 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
I plan on deleting the AC and Smog pump at the same time.
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
LittleFranks
Sep 17, 2015 12:22 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
