after market starter problem
Old Mar 15, 2005 | 01:47 AM
87pontiac's Avatar
Car: 87 Firebird
Engine: 2.8l-(350 on the way)
Transmission: auto-(for the wife)
I recently replaced the starter on my 2.8L V6 MPFI engine and it now makes alot of noise when it engages the flywheel.The kit came with a shim,but when I used the shim,the noise was worse than without the shim installed.In both instances the engine would still start,but what noise!
Could it be an alignment problem?If so,can you purchase different size shims?
If anybody has suggestions or has had a similar problem, please let me know.
87pontiac
Old Mar 15, 2005 | 02:49 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I would return it and try anothe rone but it sounds like a shim problem. Did it do it with the old one maybe your teeth on your flexplate has missing teeth?
Spyder_TheGamer
Dec 25, 2015 05:07 PM
gta power
Aug 13, 2015 06:15 AM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
