Any one else have this problem?
Old Mar 25, 2005 | 11:17 PM
89rs_1's Avatar
Car: 89 rs camaro and 01 mustang
Engine: 2.8 v-6 and 3.8 v-6
Transmission: auto and 5 spd
my battery dies from full charge after it sits for 4 days. i checked for a constant draw but have very little no more than normal for the radio and computer. put in new battery and yet again 4 days later it ****s out. any one ever experienced this? any info may help thanks allot fellow third gen lovers lol.
Old Mar 25, 2005 | 11:45 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
so,......................how much draw do the radio & computer draw?????
Old Mar 25, 2005 | 11:51 PM
89rs_1's Avatar
about 60 milli amps
Old Mar 26, 2005 | 12:11 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
If you go back to square one did you verify that the battery was charged when you let it sit? And it's brand new? Make sure your Alt isn't failing leaving it running off of the battery. No offense but I've seen (and myself included) people over look the most obvious.
Otherwise, are the wiring harnesses in good condition/ I've found a couple of problems like this on mine. Check all of the connections especially in the engine bay (ie. follow the leads from the battery, I had a bad connector at the alternator, and AC compressor). They're not easy to find especially in this situation. Follow wiring harnesses and see where they would touch metal (ground) and check if it's worn.
Mine used to run funny when it rained because of the AC connector.
Old Mar 26, 2005 | 12:24 AM
89rs_1's Avatar
thanks
ill check that out it annoys the crap out of me i want to drive it and spend all day charging it up. no one told me camaros were electric cars lol
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
