Plug and wire recommendations...
Car: '88 Camaro
Engine: 2.8L - V6
Hey all...I'm pretty new to this board and Camaros in general. My girlfriend's dad just brought down her 88 - 2.8l she had when she was a kid, so I'm doing a tune-up on it. I've found TomP's tune-up which is and excellent checklist, however, I'm looking for spark plug and wire recommendations. I've done a search and haven't found any for the V6. There are a lot of plug recommendations for a whole bunch of different headers, but this girl is all stock.
What brand/make/model of spark plug and plug wires do y'all recommend for a stock 2.8l??
I would also add to TomP's tune-up checklist to check/replace the thermostat. That was one of the first things I had to do to this guy. A $10 part could save you a whole lotta pain.
Car: 91 Firebird
Engine: 191ci 6cyl
from everything I've read the ac delco copper plugs are the best plugs to run. I got Bosch wires just cause they were all I could get my hands on quickly.
Car: 1986 Firebird
Engine: 2.8 V6
I ran Splitfire SF2C's for years until I got an MSD box; my MSD box chews the hell outta the center electrodes. The purpose of Splitfires was to expose more of the spark to the air/fuel mix, NOT to split the spark like 99% of the world thought! Splitfires acted like a cut plug (racing), but cut plugs wear out too fast.
Now I run AC plugs (R42TS) but the center electrodes still wear out- just not as fast as the Splitfires did.
I can say, tho, to avoid Accel u-grooves. Know the terminal of the spark plug that the plug wire clips to? Well Accel brags that their terminals are brass. Those brass terminals unscrew, get loose, and cause a misfire. I thought I got a bum set until I went to the store, opened some boxes, and saw that ALL the terminals were loose! Things might have changed; that was about 9-10 years ago, but they're not really worth the headache.
Other than that, plugs are plugs, there's really no miracle spark plug out there. Change 'em once a year, gap to spec, and you should be OK. I could never own a new car with those "100,000 mile platinum plugs" b/c I'd be changing those plugs out every year.
As far as spark plug wires, whatever you want- as long as it's not a cheap $15 set. Cheap sets are made cheaply, so they wear out fast, leak spark, etc. To check for spark leak, at night, pull over where there's no streetlights and open the hood- you'll see blue sparks jumping out of the wires.
If you buy a "universal" spark plug set, you cut those wires to the length you want and crimp the distributor ends on. I use universal sets b/c I route my spark plug wires over the valve covers instead of the hard-to-reach factory routing.
Find specs on the Accel wires at http://www.mrgasket.com . Any aftermarket set of wires should do ya right. I wouldn't go higher than 8.5 or 8.8 mm if you've got a stock ignition. I think some guys run the THICK Taylor 10.5's, but if you're stock, it's just a waste of coin.
Try not to get grease or oil on the wires when you install them, wash your hands first. Grease/oil can get into the wire's insulation and cause spark leak.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I'm suprised MSD hasn't beenmentione dyet (even though I have accel wores again
I have bosch wires on teh blazer along w/the =$s and netted some good highway milage improvement. And yes, I've heard on other boardsas well that if you run an ignition box, avoid teh platinum plugs.
)I have bosch wires on teh blazer along w/the =$s and netted some good highway milage improvement. And yes, I've heard on other boardsas well that if you run an ignition box, avoid teh platinum plugs.
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
