Head porting question, gasket matching to intake
Old Mar 30, 2005 | 09:45 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I know a few of you guys have ground your own; did you do any gasket matching where the head meets the intake manifold? If ya did, was there much to remove, or not much of anything?
Old Mar 30, 2005 | 09:57 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I just basically de-burred mine. Didnt really port of polish. I found a few burs where the molds met, etc.
Old Mar 30, 2005 | 02:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That's basically going to be my plan; just nix any sharp edges... then I remembered about gasket matching! Did you use stones or sandpaper rolls? I've seen a few "port/polish" kits that come with sandpaper rolls; seems like the way I'll go.
Old Mar 30, 2005 | 04:27 PM
Dale's Avatar
Engine: 350 S-TPI
Honestly, at this moment I cant remember what I used.
it either went on my dremel, or chucked into dads air drill.
Old Mar 31, 2005 | 09:21 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i port matched my gaskets. its not hard. i don't recall there being much material that had to be removed on the gaskets. i think i used a combo of rolls and stones.
Old Mar 31, 2005 | 07:24 PM
KED85's Avatar
Quality of the drill high speed tool dictates the best result with either sand paper or the metal bits.
You will be "pushing" on main drive shaft bearing so cover that one detail in drill purchase.
Truly on these heads, not much to remove at all, cause it's such a high quality head casting, compared to old small block chevy heads.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
TreDeClaw
Aug 14, 2015 06:58 PM
89-S-dime
Aug 12, 2015 11:57 AM
