Code 44 and 45
Old Apr 6, 2005 | 04:48 PM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
Code 44 and 45
I recently wrote about my 90 camaro 3.1L getting a code 45. I havent had time to check out for vacuum leaks. Recently, everytime I come to a complete stop, it seems my engine drops in rpms and shuts off. Luckily, I put it on neutral and turn it back on. But the wierd thing is dat everytime I start my engine, it revs up literally. Has someone every came up on this situation before, I know its long but Im sure someone knows about my situation.
Old Apr 7, 2005 | 08:34 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
When the last time you...
- checked the oxygen sensor wire to make sure it wasn't cooked on the exhaust pipe?
- adjusted the timing?
- cleaned the throttle body?
- cleaned the IAC system?
While you do that stuff, remove & clean & re-gap the spark plugs. Also check each spark plug wire with an ohm-meter/multimeter to make sure they're within spec of each other. (Example; you have 5 wires that read between 50K-65K ohms, but the sixth wire reads 500K ohms. You know that 6th wire is bad.)
Old Apr 19, 2005 | 02:37 PM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
i pretty much changed the throttle position sensor and the air valve control sensor and yes i did clean the throttle body, but i dont have an ohm reader to check the wire cables for the spark plugs. it still runs fine, but dunno if its spitting codes still.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
