oil leaks???
Old Apr 7, 2005 | 01:48 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
oil leaks???
My 2.8 has a pretty nasty oil leak. You park it, and you have a slight puddle after a short while. Basically you can empty out a couple quarts between 3,000 mile oil changes My car has also "marked" it's territory in the parking structure
I read that the distributor o ring is known for going bad. Also, the cam plate as well (i think that is what it was). I was wondering what the cam plate is/where it is located (back/front of engine?) My leak seems to be coming from....the back.... I know the distributor is in the back.....and does not look like fun to pull!
Any hints/pictures/advice would be really appreciated!
-Justin S.
Old Apr 7, 2005 | 05:15 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
good chance its both. the distributor o-ring is an easy fix. pull the distributor, replace the ring, also get a chevy small block distributor gasket for extra insurance.
the rear cam seal is harder. it requires the trans and flywheel/flexplate to be removed. its on the back side of the engine toward the top of the block. its a dealer-only part. about $13.00 if i remember correctly.
Old Apr 7, 2005 | 05:45 PM
KED85's Avatar
YOu could have a traveling oil leak, too.
Try the oil filter housing up at oil filter
Try solving the teh distb oring deal first, tho.
Add a small block chevy distributor gasket, before ya sink back in the MPFI distb.
Extra insurance at $1.
While distb out seek out my past thread abotu rebuilding the distributors, it's pretty easy. Not too costly either.
How to access
Go to SEARS get 15mm SWIVEL HEAD SOCKET & Bag of extension. Have at it
Rear main seal & rear cam seal are accessed ONLY BY removing tranny & flywheel/Torque convertor.
BOTH ARE NECESSARY when doing a tranny job! Both those seals at GM dealers, too. Because those seals can leak, too!
Old Apr 8, 2005 | 02:05 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Wow, thanks for the info guys. Lots of good info here! That distributor one sounds okay, but I'll leave the cam one.....till the tranny has to be rebuilt!
Thanks!
-Justin S.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
